Headlights still not working!
Old Feb 9, 2015 | 08:18 PM
80ford100's Avatar
80ford100
I pulled my 300 engine and painted the engine bay and then dropped in a 351w. I have an LMC heavy duty headlight harness installed along with all new grounds from the battery, to the engine, to the frame. The grounding strap from the intake to the hood is in good shape and the ones under the dash pad looked good. I swapped the dimmer for a known working one and went through 2 different headlight switches from the local parts store. The two new ones when install and turned on did nothing so I took those back. The original one shows no sign of melting or wear. When it is pulled to the first click all the dash lights and running lights work. When you pull it all the way out the dash and running lights go dim and flicker but no headlights come on. The switch makes like a clicking or scratching sound when in the headlight position but not when it is in the running light posistion. Im stumped and don't know what to do next. I need the truck for the 14th so time is ticking.
Thanks, John
Old Feb 9, 2015 | 08:54 PM
ctubutis's Avatar
ctubutis
The clicking could be the built-in circuit breaker in the switch tripping...
Old Feb 9, 2015 | 09:38 PM
80ford100's Avatar
80ford100
What does this mean and how do I fix it?
Old Feb 10, 2015 | 09:16 AM
bcamill's Avatar
bcamill
Did you reinstall the dimmer to the floor yet? I ask as it needs to be grounded to make the headlights function correctly. It cannot be plugged in and sitting on the carpet.
Old Feb 10, 2015 | 10:37 AM
80ford100's Avatar
80ford100
Yes the dimmer is completely bolted in.
Old Feb 10, 2015 | 10:43 AM
bcamill's Avatar
bcamill
Just for fun, did you run a wire and ground directly to the headlight to be sure both did not blow? Ground to the post at the top of the bulb, then 12 volts to either side for low and high beam.
Old Feb 10, 2015 | 10:51 AM
80ford100's Avatar
80ford100
I ran a jumper ground wire from the battery to the core support but that didn't help. Both lights worked before the swap and I even changed one for a known working one I had on my bench.
Old Feb 10, 2015 | 10:58 AM
bcamill's Avatar
bcamill
OK, I fell for you. I have run into some weird wiring in the past, but eventually figured them out. Since you changed the wiring harness, I started to worry. There is really nothing to is. Power, ground and switch. How about getting some power to the plug at the switch. If lights come on it is switch, if not, wiring issue. Then continuity test is needed for all lines.
Old Feb 10, 2015 | 11:01 AM
ctubutis's Avatar
ctubutis
If the built-in circuit breaker is constantly tripping, this means you most likely have a dead short to ground somewhere.
Did you install this LMC harness when you changed engines and the problem then began? If so, that implies something is wrong in the wiring of that harness...
Old Feb 10, 2015 | 11:03 AM
80ford100's Avatar
80ford100
The headlight harness is kind of a thing of its own. It has 3 connectors on it, 2 for the headlights and one male to plug into the old headlight plug. It just bypasses from all the energy running through the switch. Its hard to explain with my lack of electricity and wiring knowledge. Its in the lmc website of you want to take a look. I must be getting power at the switch because the dash lights And parking lights come on right?
Old Feb 10, 2015 | 11:05 AM
80ford100's Avatar
80ford100
The harness was installed when I had the 300 and worked great. Im starting to thing because I painted the inner fenders where they ground that it isn't getting a good connection?
Old Feb 10, 2015 | 11:44 AM
Tedster9's Avatar
Tedster9
The new paint is (often) a likely culprit.
Old Feb 10, 2015 | 12:01 PM
ctubutis's Avatar
ctubutis
Sounds to me like there is too much of a ground someplace where there shouldn't be. Use your ohm meter to see if you have continuity between any of the headlight wires and ground; if you find a wire that shows such continuity, you found a wire with a problem somewhere.
The act of painting (or changing an engine) might have caused some insulation to be scraped or chaffed and a wire shorted to ground somewhere.
Old Feb 10, 2015 | 09:09 PM
80ford100's Avatar
80ford100
Okay guys I fixed it. Turns out since one of the old pig tails for the headlights isn't used because of the new harness, it sat to the side. I geuss bouncing around caused the plastic plug connector divider fell off causing the ground and positives to touch. Who would have known!
Thanks, John
Old Feb 11, 2015 | 09:16 AM
1986F150six's Avatar
1986F150six
You nailed it, ctubutis!
mgillanders
Dec 22, 2014 12:01 PM
69bluebeauty
13
Dec 14, 2012 01:05 PM
aintskeered
Feb 20, 2012 09:20 PM
Vinford
Mar 27, 2009 11:08 PM
GeneStoner
25
Nov 8, 2003 10:24 PM
