Rear Diff ?
Old Mar 21, 2010 | 08:31 AM
SNSTER's Avatar
SNSTER
Rear Diff ?
I have a 77 F-250 with D60 with an open diff. The truck is going to be used as a driver and to pull the boat to the lake when the resto is complete. Now the old lady will be backing the boat in since she cant drive the boat to save her life so I would like to lock the rear up incase she gets it too far into the water. I know you could use the 4x4 but she is a woman and I dont have the patience to explain it lol. So I was looking at a locker like:
Detroit Locker Dana 60, 16 Spline 4.10 and down
How would that work for a street puller truck?
Old Mar 21, 2010 | 11:56 AM
SNSTER's Avatar
SNSTER
Anybody using one of these?
or would this be a better option?
D60 35spl Power-Loc Complete 4.10dwn
Old Mar 21, 2010 | 12:26 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
I would go with the Powr-Lok. Those things are tight enough that you'd never slip it on a boat ramp. Keep in mind your rear axle is only a 30 spline. For that reason....I'd never put a Detroit locker in one used for towing. Whenever you are accelerating from a stop while turning......such as pulling out onto the highway......your entire rig is being pulled by the inside axle shaft ONLY. The outside wheel is simple free-wheeling. That's WAY too much stress on that little bitty shaft.
A Powr-Lok will STILL apply more torque to the inside wheel. However, the Powr-Lok will slip before the axle goes pop. There is no slip with the Detroit.
HillbillyDeluxe81
Double post....
Old Mar 21, 2010 | 01:02 PM
RJR99SS's Avatar
RJR99SS
detroit locker is probably the most popular. works like a posi, except it physically locks the wheels, doesnt mess around with clutches or anything, so it's way more durable and heavy duty. i have one in my 77, love it. i dont know much about other lockers.
I do know that some dana 60 rears have 16 spline shafts, some have 30 spline shafts, cant remember which went into which models or years. my 77 had 30 spline shafts though. might want to pull a shaft to check, just to be sure before you buy anything.
Old Mar 21, 2010 | 01:42 PM
SNSTER's Avatar
SNSTER
so since I will be pulling with it on road situations the power lock would be the better option? The aussie locker will probably be going in the front so if it ever got real nasty I'm sure it could crawl its way out
Old Mar 21, 2010 | 01:53 PM
HillbillyDeluxe81
Once again, Detroit only applies torque to one axleshaft in a turn. Not a good idea when you have an axleshaft weaker than a 4 cylinder ranger shaft. For street or off-road use, it would be fine because the tire will usually slip first. However, with a heavy load and a heavy foot, the axle shaft may go 'pop' before the tire spins. There is no way I'd ever tow with a Detroit and 30 spline Dana 60.
To put things in perspective, I tow a gross combined of about 15,000 in my 05 F-150 on a regular basis. I would be concerned with putting a Detroit in it......and it has more beef in the axle than a Dana 70. Whenever I'm pulling out on the highway from a stop, I just don't like all that torque going to just one shaft. Maybe I'm just too paranoid.
HillbillyDeluxe81
Double post......again
Old Mar 21, 2010 | 02:00 PM
HillbillyDeluxe81
Yeah, as long as you're not actually backing down into a creek, the Powr-Lok would be a much better choice. I have one going in my Dana 70 HD.
Old Mar 21, 2010 | 02:04 PM
HillbillyDeluxe81
The Detroit is nothing like a "posi". Positraction is a GM / Eaton trademark for a limited slip differential. You're correct about the Detroit being very durable and heavy duty. However, the axle shafts are not...... Seriously, they are weaker than a 28 spline Ford 7.5 shaft.
Old Mar 21, 2010 | 02:24 PM
SNSTER's Avatar
SNSTER
thanks for the info power-lok it is
FordTruckGuy96
34
Aug 11, 2016 05:41 PM
61FordF-250
Sep 27, 2015 01:48 PM
V10E350
Mar 12, 2015 06:22 PM
lafermedavid
23
May 19, 2013 06:18 PM
Fordman96
1978 - 1996 Big Bronco
Apr 27, 2013 05:01 PM
