Differential Choices
Thx.
> when the hubs are unlocked, right?
Sort of, but, using it that way at highway speeds would not be good.
> Do I want to keep a LS differential in the back?
Open with a selectable locker or a L/S selectable locker.
> Currently the rear has a 410 Limited Slip. Do I want LS all around? W
Selectable lockers all around if you can afford it, especially in ice and snow.
I would use the E-Locker or ARB so you could switch the front locking diff. out for most of your off road and on-road (snow, ice, boat ramp) driving.
If you have a detroit locker in front, engage the driver's side hub, put it in 2x4 and go for a drive and tell me how the steering feels at 55 mph. Even worse for a 4x4 van.
I want to add either a limit slip or locking differential to either both front and back or just back. From reading on the topic it seems there are multiple options, but I am struggling determining what is best for me.
My situation:
90% of the time I am driving on dry pavement (which makes the open diff just fine). The other 10% of the time I am not doing any aggressive off-roading, however even if I am off road or in the snow I want to ensure I am in a position to have the most traction available.
My goal is to find the most reliable / flexible option available. For example, ideally (if it exists) I am thinking a high quality locking / limit slip / open diff all in one that can be set to the desired option. I will not beat/abuse this vehicle so I want it to last the life of the truck as the stock diff. should.
Questions:
- If I have the locking option is there any value in having limit slip? I read several posts about front locking being a bad thing when turning in the snow due to vehicle not responding as expected, which I understand. For this reason it seems the selectable limit slip option would be best in front. Feedback?
- I see so many options (i.e. ARB, Eaton G80, TruTrac, etc.). Any recommendations for my situation?
- I have seen aftermarket diff. gear installations in the past where the gears would whine. I understand some (or maybe all) of this could be the fault of the installer not setting the bearing preload / gear backlash, etc. correctly. I would want the new diffs. to be no noisier than the existing stock (which are quiet). Is that a realistic expectation? Any experience between aftermarket diff. options on which one is the quietest?
- Will a new diff. have a potential impact on the vehicle's existing traction control system? I am more concerned with the system triggering a "check engine light" if it detects a condition that is abnormal to what the stock vehicle would see.
- By converting to a new diff. what components are impacted? What stock components would / could be reused?
- I read a post where someone said if you have an open diff and the tire with less traction is spinning, applying the brake (in moderation) will sort of act like a limit slip and help deliver more power to the wheel with traction. Does this sound accurate?
- Is it justified to modify both front and rear diffs? What about something different between back and front? Maybe limit slip in front and locking in rear? Again I want the option to switch each back to an open diff style for dry pavement driving conditions?
- What is the best way to search for/find a "true" professional that could perform the installation? Would the manufacturer's of the aftermarket diff's be able to suggest the "right" person?
Thanks
Power transfer is seamless, no jerk or rachet feeling.
Just wish they made them for my D50 up front. I'd install one in a heartbeat.
Just my 2 cents
Todd
