1978 - 1996 Big Bronco
96' Bronco Spline count
Old Apr 26, 2013 | 06:44 AM
Fordman96's Avatar
Fordman96
Hey all. I've been doing some research on switching my Ford 8.8 to a Truetrac and my front D44TTB to and Eaton E-Locker. I just need to know my spline count for them (they came with 3.55s but now have 4.10s.)
Eaton 19747-010 - Eaton E-Locker - Dana 44 30 Spline (3.92 & Up) for the Front
Eaton 913A561 - Detroit TrueTrac Locker - Ford 8.8" 31 Spline
for the Rear.
Will these work?
Old Apr 26, 2013 | 07:57 AM
NASSTY's Avatar
NASSTY
Yep, those carriers will work. I have the Truetrac in the rear of my Bronco with 4.10s.
Old Apr 26, 2013 | 06:03 PM
Fordman96's Avatar
Fordman96
I was thinking those with my current gears then getting stub D50 axle shafts for my D44 for strength. Kemical mentioned something about it.
Old Apr 27, 2013 | 11:08 AM
Kemicalburns's Avatar
Kemicalburns
i am sure you know this but that E-locker acts as a limited slip when its not engaged. you might think about putting the E-locker in the back and the trutrac limited slip up front.
the D50 stub is a cheap strength upgrade, i am not running one yet but have thought about it.
Old Apr 27, 2013 | 12:57 PM
Encho's Avatar
Encho
The Southernmost Mod
D50 stub? what do you mean Kem?.
Old Apr 27, 2013 | 02:03 PM
Conanski's Avatar
Conanski
+1.. and the Ford 1/2 ton axles are 31 spline.
Old Apr 27, 2013 | 05:01 PM
Kemicalburns
you can swap a stub shaft from a Dana50 ttb axle in place of the stub shaft on the stock d44 axle. the stub from the D50 is larger and less likely to fail
diymirage
Jan 19, 2018 10:54 AM
Mush's 88
Jan 10, 2005 12:36 AM
sailboat2323
Aug 16, 2003 11:39 PM
JBronco
Jan 7, 2003 04:12 PM
