08 6.4 rad prob
What about thermostats?
This may help:
Printable View (69 KB)
TSB
09-23-1 6.4L DIESEL ENGINES - REPEAT RADIATOR LEAK - BUILT ON OR BEFORE 9/14/2009
Publication Date: November 9, 2009
FORD: 2008-2010 F-Super Duty
ISSUE:
Some 2008-2010 F-Super Duty vehicles built on or before 9/14/2009 and equipped with a 6.4L diesel engine may exhibit repeat radiator leaks due to malfunctioning (hyper-extended) high temperature thermostats.
ACTION:
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Verify the coolant leak is from the radiator, refer to pin point test (PPT) A found in the Workshop Manual (WSM), Section 303-03.
Verify the venturi tee is installed.
If installed, confirm it is installed correctly (note - orientation direction on part). Refer to applicable Field Service Action (FSA) for vehicle built on or before 5/15/2008.
If not installed, install per applicable FSA on vehicles built on or before 5/15/2008.
Prepare the vehicle for a test drive.
If the coolant leak at the radiator is large enough to cause an unsafe test drive or potential for engine/vehicle damage, proceed to Step 5.
Before driving the vehicle confirm the coolant level is at minimum level or above in the degas bottle. If required add 50/50 mix to coolant bottle.
Test Drive - use an Integrated Diagnostic System (IDS) or equivalent and monitor engine oil temperature (EOT) and engine coolant temperature (ECT) parameter identifiers (PIDS).
With EOT at 195 °F (91 °C) drive on the highway unloaded at 55-70 MPH (89-113 Km/h) constant speed to observe EOT and ECT temp.
Test results/next steps:
If EOT is less than 8 °F (4.4 °C) higher than ECT, and the coolant temp fluctuates roughly 5 °F (2.7 °C) - the thermostats are okay and do not need to be replaced. Replace just the radiator. Refer to WSM, Section 303-03 (Engine Cooling).
If EOT exceeds ECT by greater than 8 °F (4.4 °C) or if the ECT readings fluctuate 10 to 12 °F (5.55-6.66 °C) roughly every 30 seconds - replace both thermostats and radiator. Refer to WSM, Section 303-03 (Engine Cooling).
If vehicle is not drivable and the coolant leak is found to be from the radiator, remove and replace both thermostats and radiator. Refer to WSM, Section 303-03 for both radiator and thermostat removal procedure and approved cooling system draining, filling and bleeding procedures.
PART NUMBER PART NAME
8C3Z-8575-D Thermostat Assembly
8C3Z-8009-B Radiator Assembly
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
092301A 2008-2010 F-Super Duty 6.4L: Pressure Test Cooling System, Road Test, Monitor PIDS, Replace The Radiator (Do Not Use With Any Other Labor Operations) 3.0 Hrs.
092301B 2008-2010 F-Super Duty 6.4L: Pressure Test Cooling System, Road Test, Monitor PIDS, Replace The Radiator, And Thermostats (Do Not Use With Any Other Labor Operations) 3.8 Hrs.
DEALER CODING
BASIC PART NO. CONDITION CODE
8575 42
As far as I have read/know, 3yr/36,000 mile and then get your credit card out. Shame. All the BS about engine warranties and our engines can run withOUT a radiator.
I was thinking about a 2011. Some of the machinizations of FORD are causing me to rethink further purchases.
Sorry, but I bring no good news for you. (and no good news for me)
