While I'm replacing the head gasket...
Old Mar 20, 2010 | 07:03 AM
blue92f150's Avatar
blue92f150
I have a 92 with the 300 (~130k miles) that has been losing coolant and I noticed the dreaded milky oil and some frothing. So, I obviously need to replace the head gasket. I'm also hoping it's *not* a cracked head, but will that be *obvious*?
Now, while I'm in there, what else should I do? I really don't want to spend much, but I was looking to get some more power since I'm going to be towing a small boat (~4000lbs).
I've also heard people talk about putting ARP studs into the heads, but I'm not sure exactly why...
I have already cut off the dual cat's and replaced with a single high-flow and a magnaflow muffler, so I'm not going to do any more exhaust work.
Anything on the intake side I can do? I believe I have speed-density too.
And, as a last question, I'm assuming that I'll need the following gaskets when I'm replacing the head gasket - head (of course), valve cover, upper intake, lower intake, exhaust. Any more? Any *special tools* I'll need to get the head off?
Suggestions?
Thanks. Jim B.
Old Mar 20, 2010 | 07:44 PM
rikard's Avatar
rikard
Before pulling the head do a compression test or combustion dye test to determine if the head gasket is leaking. Its not a common issue with the 300 but it happens. Check the PCV system for proper function.
regards
rikard
Old Mar 20, 2010 | 09:32 PM
johnboy427's Avatar
johnboy427
You should just be able to buy a head gasket set that has every thing you need in it. As for head cracks they can be very obvious or almost impossible to see. Unless you have gotten it hot or let it freeze I wouldn't worry too much about cracks, if you really want you can have it magged at a machine shop.
-John
alleyoopster
1983 - 2012 Ranger & B-Series
16
Oct 17, 2019 09:54 PM
crazed87bronco
Jul 6, 2011 01:47 PM
bsiebert
Nov 21, 2010 01:30 AM
JimNolan
Jan 26, 2010 05:47 PM
BlueOvalBud
21
Jan 10, 2010 05:50 PM
