Head Gasket Questions
Old Nov 20, 2010 | 12:16 AM
bsiebert's Avatar
bsiebert
So I'm putting together an 88 302 out of a Thunderbird. I took the heads off and am replacing the head gaskets. The head gaskets I bought were Fel Pro 9333PT1 from O'Reilly's.
Fel-Pro 9333PT1 - Head Gasket 1988 Ford Thunderbird | O'Reilly Auto Parts
As I was putting the heads back on I noticed that the gaskets only have holes for the coolant passages on the back of the gasket. The block and head have passages open in the front and the gasket is blocking it. The back of the block and heads also have coolant passage holes and the gasket allows them to be open. I guess what I want to hear is that this is normal and that the gasket is SUPPOSED to block these passages on the front of the block.
Another question I have is that the directions state that bolts that thread into coolant passages or by coolant passages have to have sealant on the threads. I was wondering which of these head bolts need this treatment and what exactly I should use.
I hope this is not to confusing. If it is I'll have to get paint shop out and do some more explaining! Thanks for any help in advance!!
Brandon
Old Nov 20, 2010 | 10:54 AM
Blurry94's Avatar
Blurry94
Yes they are supposed to be blocked. Otherwise water would just flow though to the crossover on the intake and out through the coolant neck which would keep the heads from being cooled properly.
I don't remember which bolts need sealant, but you could put it on all of them and it wont hurt a thing.
Old Nov 20, 2010 | 11:50 AM
USArmyTaterness's Avatar
USArmyTaterness
Never hurts to seal all of them but using a flashlight shine it down the bolt holes you will be able to see which are wet and which are dry.
Old Nov 20, 2010 | 06:37 PM
bsiebert's Avatar
bsiebert
Awesome. Thats the answer I was hoping for. I'll take the flashlight out and see, I don't know if that is the solution though because it has been sitting on the stand for a couple of weeks so I may not be able to tell. Thanks for the help!!
Brandon
Old Nov 20, 2010 | 09:04 PM
Beanscoot's Avatar
Beanscoot
I think that all the threaded holes are "blind" i.e. don't go into the water jacket. The gasket instructions are generic and apply to engines that do have head bolt holes that extend into the coolant.
Usually some of the threaded holes are filled with oil or coolant that leaked in from above, so it's difficult to see the bottom. This liquid should be sucked out with a small turkey baster or similar. Otherwise it can hydraulically lock when the bolt is screwed in, giving false torque readings or even splitting the casting. You can check if the holes are blind by poking with a skinny screwdriver.
The head bolts should be lightly coated with engine oil upon reassembly.
Old Nov 21, 2010 | 01:30 AM
USArmyTaterness
Normally on Ford's we don't need to worry about wet head bolts but they do exist on certain years and models.
SoCalAngler
37
Apr 22, 2014 08:46 PM
husker77
Mar 28, 2013 05:40 PM
husker77
Apr 23, 2012 02:15 PM
drmgoat
Dec 3, 2007 05:41 AM
scup
15
Mar 15, 2002 10:13 AM
