first time replacing head gaskets 460
Old Jul 5, 2011 | 03:09 PM
crazed87bronco's Avatar
crazed87bronco
i'm refreshing my 70's internal balance 460 some replacing alot of the gaskets and giving it new paint i want to replace the head gaskets on it but never done it before can anyone give me some advise on what to all look out for and any tips/tricks to doing it i have it on a engine stand and have the intake timing cover oil pan oil pump and all accesories off only thing left is the heads before i loosen the bolts is there anything i need to mark like pushrods or can they get put back in in any order or use them in the same place they came out of? also can i get thinner head gaskets to raise the compression? or will this cause problems with valve clearance issues
Old Jul 6, 2011 | 12:00 PM
eazye2000's Avatar
eazye2000
I would recommend that you keep the rockers and push rods in order. The push rods have worn themselves to their respective rocker/lifter.
And I don't think it's necessary, but I keep the bolts in the same order as well; just a pet peeve of mine.
The only thing I found to be a pain in the ***, was making sure I had a little RTV around the coolant passages. I used Engine Tech gaskets and they were a little sketchy upon visual inspection. There are also straight up studs (on an EFI motor) that are usually all corroded; be careful upon cleaning those up.
Other than that, I say use a wire wheel with low pressure to clean everything up real well. Also if you're new to headgaskets, make sure to drain the coolant; it gets a bit messy if you don't!
Pretty much put it back together the way you took it apart, is generally the same order.
That's my $.02
Old Jul 6, 2011 | 12:49 PM
crazed87bronco
Thanks does anyone know about using a thinner head gasket to raise the compression? I bought the felpro engine overhaul gasket set that included head gaskets wondering if these are good enougb orshoild i buy some better head gaskets
Old Jul 6, 2011 | 01:01 PM
eazye2000's Avatar
eazye2000
If they are the blue ones, they are the better Permatorque ones I believe.
And I wouldn't mess with raising compression with the headgasket. I don't know much about it, but lifter pre-load and all that jazz comes into account when you start messing with that stuff.
Did the headgaskets blow just because, or did the motor overheat? I would get the heads surfaced, and have the valves done too while I was at it if it overheated. My heads were way out, and my gaskets didn't even blow; it just overheated a little bit.
Old Jul 6, 2011 | 01:47 PM
crazed87bronco
The motor was good from what the guy said that I bought it off of got it out of a parts truck the motor doesn't look like it blew any gaskets I'm refreshing it with new gasket to keep it reliable in my winter truck
DrZoom
20
Dec 22, 2016 09:13 AM
MI02SVT
Apr 19, 2016 05:18 PM
DPDISXR4Ti
31
Jun 19, 2012 07:41 AM
Smurf-Slayer
Jul 22, 2007 09:56 PM
nminer1
Apr 19, 2005 10:28 AM
