Roller Tip not centered on valve stem
Old Mar 18, 2010 | 01:17 PM
pagokid59's Avatar
pagokid59
I'm rebuilding a 65 289 (my first!) with 351W heads and the sportsman roller tip rockers I installed are not centered, side to side, on the valve stem. They look dead center front to back but I'm concerned that they might slide off the side of the stem. They are stud mounted and I'm using guide plates as well. Should I be concerned or will they center up them selves once I get it running?
Old Mar 18, 2010 | 02:27 PM
MBDiagMan's Avatar
MBDiagMan
What are you calling front to back? Do you meand front to back relative to the vehicle or relative to the rocker arm?
When you check push rod length, you should see a line across the valve stem that goes in the same direction as the vehicle and should be centered on the valve stem side to side with respect to the vehicle.
Old Mar 18, 2010 | 02:32 PM
pagokid59's Avatar
pagokid59
I meant in relation to rocker. In relation to the vehicle, it's not centered front to back, does that make sense? Thanks
Old Mar 18, 2010 | 05:00 PM
1bad67sbf's Avatar
1bad67sbf
thats wierd could the studs have been installed wrong (im assuming you have ford 351w heads not aftermarket)
Old Mar 18, 2010 | 05:52 PM
pagokid59's Avatar
pagokid59
351w heads, D0OE castings, the studs look alright ...I think
Old Mar 18, 2010 | 06:15 PM
1bad67sbf's Avatar
1bad67sbf
1970 heads for a car. not bad heads did you port them? and check are the distance between each stud to see if they are the same w/ a micrometer (i cant think of any other way to check) are all off center the same or only some?
Old Mar 18, 2010 | 06:37 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Is there side-to-side play in the rocker? It's held in alignment by the guide plate, so if there's play you may have the wrong gp/pushrod combo.
Old Mar 18, 2010 | 09:39 PM
pagokid59's Avatar
pagokid59
I hit them with a micrometer and all stud to stud (intake to exhaust) spacing is the same, as well as valve stem spacing. I mean should the stem be directly in the center of the roller? None of the stems are "outside" of the roller, just some are dead center and some aren't. The po had the heads ported and polished but he got rid of his project before ever installing them, that's all I know about them. When I got the block machined I had the shop take a look at the heads and was told that they were excellent.
There's a minimal side to side play with the valve fully closed, more of a pivot/rock around the pivot ball in the center of the rocker arm than a side play.
This is my first rebuild so hopefully you guys can set me straight...
Old Mar 18, 2010 | 10:04 PM
Conanski's Avatar
Conanski
There was a hugh thread on this very subject over on the Corral forum and the final call made by some very experienced engine builders and backed up by engineers was that NO.. the rocker tip doesn't have to be perfectly centered in the valve stem. It should be towards the center obviously to minimize side loading of the valve stem but the main thing is to set them up so the movement pattern is as narrow as possible. And to do this right with stud mounts is a bit tricky, you have to set the rocker height so that it is perpendicular to the valve stem at exactly half travel, doing so will ensure the rocker tip moves an even amount in and out on the valve stem as it travels from fully closed to fully open. This will also produce the narrowest contact pattern on the valve stem.
Old Mar 19, 2010 | 03:42 PM
HemiEater's Avatar
HemiEater
Make sure you are using the right size pushrod, guide plate and stud. 7/16 rockers on 3/8 studs, or 3/8 guide plate with 5/16 pushrods will make for problems. sounds like you might have 3/8 studs with 7/16 rockers.
Need pics..
Old Mar 20, 2010 | 09:35 AM
bashby's Avatar
bashby
I thought they were supposed to be a little off center to make the valve rotate as it opens and closes
Old Mar 23, 2010 | 09:52 PM
8bahead's Avatar
8bahead
The alignment of the guide plates will cause problems too,by alignment I mean are the push rods straight side to side,which would be front to back if the engine is in the car truck or on a stand. The push rods should have almost equal distance on either side of the slot with the push rod installed.
You dont want the push rods contacting the guide plates. Its a tedious job, pay attention to the details, and make you're first build a sucessful one!
Old Mar 23, 2010 | 10:05 PM
HemiEater's Avatar
HemiEater
the push rods rub on the guide plates all the time, they are what keep the roller on the valve tip.
Old Mar 23, 2010 | 11:33 PM
pagokid59's Avatar
pagokid59
Pushrods are centered in all guide plate slots and they are straight. After all of the advice and reading on this and the corral, I'm going to press on with what I've got. I'll let you guys know how it goes. Mahalo for all the info.
CheaperJeeper
46
Nov 24, 2017 11:22 AM
golfnut324
Dec 27, 2016 02:10 PM
brandon mauldin
Sep 23, 2014 12:55 PM
Bigfootgrey
6.7L Power Stroke Diesel
Aug 30, 2013 04:40 AM
rvpuller
Jun 22, 2005 07:11 PM
