Valve stems on dually
Old Aug 27, 2013 | 05:11 PM
Bigfootgrey's Avatar
Bigfootgrey
My dealer suggested replacing the metal valve stems on the outside aluminum rims with high pressure rubber stems to prevent corrosion. Should I be concerned? I often carry a 4000lb truck camper. The metal valve stems seem to react with the aluminum rims . Are HP rubber stems safe?
Old Aug 27, 2013 | 06:17 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I've seen rubber ones blow out with over 60psi in them on hot days.
He does have a point with the steel ones corroding if they touch aluminum though - I would personally replace them with Aluminum ones.
Something like:
4 Universal Volk Racing Silver Forged Aluminum Valve Stem Caps Wheels Rims | eBay
Old Aug 27, 2013 | 06:48 PM
69cj's Avatar
69cj
I personally haven't had any problem with either one. I am in s. ca. which would not have the same problems, possibly, as some one in the snow belt.
Old Aug 27, 2013 | 09:50 PM
porthole's Avatar
porthole
I have had the rear wheels on my DRW replaced twice due to corrosion around the stem. Each time they put the normal stems back on.
Those chinese wheels retail for $750
Old Aug 30, 2013 | 12:10 AM
Davgt500's Avatar
Davgt500
I noticed that when I had replaced my tires @ 60k the replaced my valve stems w/ rubber ones. I am currently @ 125k and have had no issues with them. On my dually I run 65 to 70 lbs in the rears and have 7500 lbs on the rear axel every day.
Old Aug 30, 2013 | 04:40 AM
Bigfootgrey
Thanks for the information. I also checked with a few tire shops and most of them felt the corrosion issue will occur around the valve stem due to clear coat failure. Either type of valve stem is fine. Liquid calcium and magnesium chloride applications are destroying our trucks!
Bob
albertatyke
Dec 29, 2020 04:20 PM
eagle275
May 23, 2016 11:25 PM
Big D 7.3
Nov 10, 2012 09:01 PM
Big Red
May 7, 2006 03:29 PM
michigandrake
Offroad & 4x4
13
Feb 28, 2006 07:36 AM
