EBPV Delete
Old Mar 18, 2010 | 09:19 AM
Talyn's Avatar
Talyn
EBPV Delete
I did this yesterday.
I had my turbo out of the truck, but most of you will have to do it in the truck.
Anyways.
If you dont use the EBPV, get that thing outa there. Its a HUGE hunk of metal with a butterfly on it that just stops air and gathers heat.
Waste waste waste!
If anyone is ever curious on how the valve moves, as I was, its oil driven with hydraulics. Hence the whole thing people have wrote about on here with welding the hole up for the actuator.
I just put it all back together and threw it in, but boy oh boy do I wish I coulda cut that big round hunk off there, would give you so much more room to work on this damn thing.
As for how to get it out with it in the truck, I'll have to leave that up to somebody else, but I just took the rivets out and slid the unit out and plugged the hole with a bolt and some washers. I wanted to use a carage bolt, but I couldn't find the nut for the only one I had (some special thread cause it was a special bolt)
I wont say you'll get performance gains with this.
The EGT's might be cooler (doubt you'll see it)
but, its a waste. get that sucker outa there.
For anyone else reading, I was wondering if i should just clip the leads off that actuator on there? I dont see why not, but maybe somebody has a reason to leave them on.
Old Mar 18, 2010 | 09:49 AM
427 fordman's Avatar
427 fordman
You shoulda cut that big round thing off the pedestal. I did when I had my turbo out. Makes the access to that bolt sooooo much easier. Just gotta weld up a few things and its outta the way. I didn't have an aluminum welder but had someone else weld it and I was so glad I did it when I went to put it back on.
Old Mar 18, 2010 | 10:06 AM
Talyn's Avatar
Talyn
No access to that for me and somebody who knows whats going on. So I just reassembled it clean and thats that for now.
xbox73
May 5, 2014 06:47 PM
frank134
1997 - 2003 F150
Oct 24, 2011 12:25 PM
Talyn
Jun 18, 2010 05:50 PM
Redmanbob
Jan 7, 2009 10:17 PM
websthes
15
May 18, 2007 01:12 AM
