PO Boy Flow Bench..
Old Jan 2, 2009 | 09:28 PM
Redmanbob's Avatar
Redmanbob
PO Boy Flow Bench..
Now before you post up this is a waste of you time, pull your head outa your ****, my girl gets better numbers after a pint of tequila etc..
I want to build a semi decent bench for the garage that will assist is R&D for a look see at things prior to spending real money on confirmation. I looked around at the web and came up with stuff like
Flow Bench
Anyone with a homemade setup getting semi accurate results on FE heads, Me so interested!!!
Old Jan 3, 2009 | 05:56 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Well I'am not to Hip on using the conversion charts etc...I also didnt see anyway to regulate the air flow coming from the vacuum cleaner ? different shop vacs will blow different amounts of CFM...and voltage drop to the vacuum will cause it to be slightly diffrent in output even "IF" you cant hear the change in the motor speed..
Air Density, Temp and speed all have to do with good ballpark CFM readings, Even on any 2 given Super flow machines..I have never seen the same head put out the same CFM at a given lift on 2 diffrent machine of the same kind?
I know your not looking to get exact numbers Bobby! But I guess it would tell you "IF" your going the right way anyhow?? Just a guess... How Much is the complete set-up cost with all the bells and whistles?
~Russ
Old Jan 4, 2009 | 04:44 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Very interesting. Much like chassis dynos, this would give you SOME idea of where you're headed, if not real actual numbers...
Old Jan 4, 2009 | 05:32 PM
Redmanbob's Avatar
Redmanbob
For what the guy wants to flow two holes I could screw for weeks
Old Jan 5, 2009 | 08:35 PM
Ford428CJ's Avatar
Ford428CJ
I thought loooong and hard about doing one myself. Just remember to line up the head to how it would sit on the cylinder. Just how it would line up with the head on the cylinder of the block! I just dont know how accurate it will be. You might want to talk with the "Mad Porter" of the 460 Forum. He might be able to tell ya. JMHO
Old Jan 5, 2009 | 08:45 PM
RapidRuss's Avatar
RapidRuss
Well one thing about it...If it didnt work for automotive heads? you can always hook a Flow Bee up too it and give Hair Cuts !! LOL
~Russ
Old Jan 5, 2009 | 08:50 PM
Redmanbob's Avatar
Redmanbob
I'd just like to set something the up rather simple that would be a half *** reasonably accurate setup to tinker with porting concepts on some junk heads(that could be had for pennies from machinist's scrap piles).
Old Jan 7, 2009 | 06:35 PM
fordeverpower's Avatar
fordeverpower
I too have been wanting to build a flow bench but the software costs a little, i have seen flowquik and other equipment used. Scott Johnston "madporter" has about as reasonable flowbench given the money. I seem to think $1000 or better is needed myself.
Old Jan 7, 2009 | 09:58 PM
Redmanbob's Avatar
Redmanbob
Any details on what he's working with ?
Old Jan 7, 2009 | 10:17 PM
fordeverpower
go to his site Rein"Car"nation High Performance and Automotive Repair / services
theres a pic, audie technologies makes the flow quik products www.audietech.com
ChocNav
Sep 13, 2011 10:12 PM
keisha9
Jan 30, 2007 04:37 PM
Mr. Finch
Appearance & Dress-Up
Mar 13, 2005 06:57 PM
Mr. Finch
Mar 9, 2005 09:05 PM
fordnut71
Garage & Workshop
19
Apr 26, 2004 04:46 PM
