Engine Removal
Old Mar 16, 2010 | 05:44 PM
hi-jacker's Avatar
hi-jacker
Engine Removal
I just had the bed plate gasket replaced in my 2005 F350 for the second time...the first time was at 20,000 miles and this time at 60,000 miles. What I find interesting is the tech who did the first repair removed the cab, but the one who did it this time did not. I asked the second tech about it and he said he finds it unnecessary to remove the cab.
It's obviously a matter of personal preference on the part of each tech, but I would think one method would be the recognized best way to remove the engine.
Old Mar 16, 2010 | 06:08 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Removing the cab isn't necessary or required...removing the engine however, is.
You have to remove the oil pan, upper oil pan, and there you'll see the bedplate. It's a simple procedure to do once the engine is out and apart.
Old Mar 16, 2010 | 07:37 PM
cheezit's Avatar
cheezit
well I hate to say it but there are a few people doing bedplates in frame. not me not gonna happen. I would rather do what I was paid for and fix it hopefully once.
there is no need to pull a 6.0 cab what so ever.
Old Mar 16, 2010 | 09:44 PM
rickatic's Avatar
rickatic
I had the engine out of my truck a month ago. I took it out the front after stripping everything from the front bumper back to the serpentine belt. Unbolted the trans from its mounts, removed the motor mounts and pulled it right out. We did remove the oil pan and oil pickup after we got it up and forward a little for more clearance. Not as bad a job as I expected. I would do it that way again
Old Mar 17, 2010 | 12:12 AM
aidanfancystang's Avatar
aidanfancystang
i got mine out the front no problems.
Old Mar 17, 2010 | 12:09 PM
scotty088's Avatar
scotty088
My engine was pulled the First week of Feb.Bedplate and all lower block seals and gaskets.I have driven it 500+ miles.Only problem was a drip of coolant on the lower hose at the radiator,I tightended the clamp with a screwdriver,end of problem.I have not heard of any bedplate oil leak issues wit 2007 6.0s though. Front end was removed and engine pulled.My hat is off to the highly trained and certified diesel techs like Cheezit and the tech that did the work for me at Northside Ford trucks in Portland,Oregon.I know there is many of them out their,Just sometimes hard to find.These are truly the professional techs that make the wheels of this great country turn.
Thanks again,for doing the job right the first time,
Scotty
Larry Lester
Oct 14, 2012 10:01 AM
toyota00
Jul 27, 2011 11:51 AM
F559
Apr 30, 2010 08:06 PM
down n dirty
Dec 22, 2008 10:19 PM
jdr1963
Feb 7, 2006 09:53 PM
