Does the transfer case take a special ATF?
Old Mar 16, 2010 | 12:03 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
Going to change out the ATF in the transfer case. Does it take a special kind?
Thanks
Old Mar 16, 2010 | 12:22 PM
solaratomic's Avatar
solaratomic
If I remember right it just takes regular Mercon
Old Mar 16, 2010 | 12:38 PM
Cowboy65's Avatar
Cowboy65
Mercron ATF - 2 quarts
Old Mar 16, 2010 | 12:43 PM
02GrayPowerStroke
Can you do it with a funnel or does it need one of those suction guns?
Old Mar 16, 2010 | 12:48 PM
Cowboy65's Avatar
Cowboy65
It can be done with a funnel but a hand operated fluid transfer pump is a much better option.
02GrayPowerStroke
10-4 Thanks
Old Mar 16, 2010 | 12:49 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
The tech folder sticky at the top of this forum is your friend
Welcome to guzzle's Transfer Case Fluid Change Web Page
Old Mar 16, 2010 | 12:52 PM
02GrayPowerStroke
I looked, just not good enough.
Old Mar 16, 2010 | 01:42 PM
cartmanea's Avatar
cartmanea
Just did mine this weekend, used Havoline Multi-Vehicle Mercon V spec fluid.
Old Mar 16, 2010 | 02:41 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Anyone have any objections to using Mobil1 ATF Syn? Just wanted to see what your thought s were?
Old Mar 16, 2010 | 02:55 PM
cartmanea's Avatar
cartmanea
Lots use the Mobil 1, I used it in my '03 about 15k miles ago. The '06 I wanted to clean it out before going synthetic, so I'm running regular Mercon V for a while before switching over.
Old Mar 16, 2010 | 03:37 PM
bismic's Avatar
bismic
I used Royal Purple Synchromax. I have about 15k miles on it w/ that fluid. All is well.
Old Mar 16, 2010 | 03:42 PM
cartmanea's Avatar
cartmanea
Yeah, the transfer case isn't too picky about fluids. Any Mercon or Mercon V compatible fluid will work, and probably a lot of other fluids.
Old Mar 16, 2010 | 06:37 PM
smokersteve's Avatar
smokersteve
It takes mercon V, used amsoil Synthetic Universal ATF that covers mercon V, and the 4X4 system is not as loud, I also have amsoil in the diffs.
Old Mar 16, 2010 | 07:21 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
Thats what I'm using, no problems so far- @ 10k miles. Have it in the rear also. Need to change the front since its getting warm now.
