Sponsored by: Auxito
Changing rear diff fluid...
Old Mar 16, 2010 | 08:09 AM
paul64's Avatar
paul64
I live 45 minutes out of town and it's a pain to have to drive in for something I may need to change for rear diff fluid on my 99 F-150 4x5 5.4.
Is there anything I should be aware of or is it pretty much standard.
1) take rear plate off
2) drain old fluid good (Do you put the front end up to drain properly?)
3) clean contact surface good on plate and read diff.
4) silicone plate good.
5) put plate back on.
6) fill with new gear oil
(Recommend FORD gear fluid or other)
(I do not see a hole to fill on plate. Where is it?)
Old Mar 16, 2010 | 08:32 AM
galaxie641's Avatar
galaxie641
The fill hole is in the top driver side front and make sure it comes out before you drop the plate off.
Old Mar 16, 2010 | 09:09 PM
steve(ill)'s Avatar
steve(ill)
you need a couple quarts of 75-w140 synthetic gear lube... and it dont hurt to put the 7 oz tube of friction modifier in the oil... if you have limit slip rear end it is a must. You cna get the tube at Auto Zone.. they have the oil, but generic is cheaper at Wal Mart.
Old Mar 16, 2010 | 09:30 PM
whitefordexplorer's Avatar
whitefordexplorer
im not 100% sure about this, but if there is a metal tag bolted or welded to the passenger side of the axle doesnt that mean its limited slip? and if your rear end is limited slip, you MUST use synthetic 90W gear lube, and the friction modifier definatly helps. I trust Valvoline lube products religiously, so thats all i use... but everyone is entitled to their wrong opinion.... LOL
Old Mar 17, 2010 | 04:10 PM
Joe Finn's Avatar
Joe Finn
Steve is correct, you need 75w-140 Synthetic fluid, not 90w. The tag on the rear will tell you if you have an LS. If there is a letter "L" after the first digit, its a limited slip i.e. 3L55
Old Mar 17, 2010 | 09:40 PM
steve(ill)'s Avatar
steve(ill)
If you have the LS unit, the friction modifier is a MUST.
Old Mar 17, 2010 | 11:01 PM
whitefordexplorer
see! i knew i wasnt that far off, glad my input (though wrong) helped out in telling you what NOT to do! LOL
Old Mar 17, 2010 | 11:10 PM
advocate's Avatar
advocate
Not sure if this is just me, but I have had REALLY good luck with leaving the diff for 24 hours before filling it with gear oil. I changed it once and filled it right away and it leaked. The next time I let it sit for 24 hours and then filled it with good synthetic 75w-140 oil and friction modifier and it has not leaked at all since.
newfie4ever
1997 - 2003 F150
23
Jun 20, 2016 08:04 PM
dracond
Jul 22, 2015 06:08 AM
bowkill
2004 - 2008 F150
Jun 23, 2013 11:35 AM
Urban_Prisoner
Jan 17, 2011 08:56 PM
mikren
1997 - 2003 F150
Sep 15, 2009 08:09 AM
