Complete TCI chassis?
Old Nov 28, 2010 | 08:35 AM
  #31
carnut122's Avatar
carnut122
Here's an old link(I'm pitiful about updating it):
carnut122 - Carnut122's 1953 Build Thread
You can scroll down and see pictures of my frame to see the differences. My front springs were also a major PITA; I'm not convinced they're the correct ones. Sorry, I wasn't clear on the rack and pinion. Those were actually Flaming River ( not Lokar) u-joint numbers to connect a generic 60's GM column to the rack. Used in conjunction with a 3/4" DD bar (part # FLA-FR1850) is enough to get mine hooked up. I just cut out floor plates yesterday(for the column and brake pedal), so I hope to hook it all up today. I found a donor shaft and u-joint from a parts car, so the only Flaming river joint I'll be using is the one on the rack. Keep us updated on your progress.
Old Nov 28, 2010 | 08:40 AM
  #32
carnut122's Avatar
carnut122
What brakes are you running on your rears? I bought a disc brake conversion from Summit for mine (it kind of looks like yours???). It has Explorer e-brake connectors on it that require a special clip(they look strange to me, so I'll have to tackle that one in the future. I'm also not sure how I'll be handling the cabling to the e-brakes.
Old Nov 28, 2010 | 09:36 AM
  #33
Toms53Ford's Avatar
Toms53Ford
The rear discs were an option. They came with the Currie 9". I see what you mean about the 4-link and the driveshaft loop. When did you order your chassis?
Old Nov 28, 2010 | 10:19 AM
  #34
Toms53Ford's Avatar
Toms53Ford
I also found the paper work for the spring compressor. OTC part # 7045B. It's a pricey tool but we found a good deal on it.
Old Nov 28, 2010 | 08:44 PM
  #35
carnut122's Avatar
carnut122
I bought mine in July of 2009. I wonder why they're different? I'm attaching the steering column to the rack and I'm making angled spacers to better align the rack to the column. the angle they have on it doesn't make any sense to me??
Old Nov 28, 2010 | 08:48 PM
  #36
carnut122's Avatar
carnut122
You're right. The best price I could find is $ 171 + shipping. Ouch! On the other hand, if I had to do it again....
Lawrencew
Aug 8, 2017 05:35 PM
ShedRat
Jun 10, 2017 10:46 PM
54-F100
80
Oct 28, 2016 01:32 PM
Lukas42104
27
Jul 11, 2012 01:09 PM
