Custom chassis question
Old Aug 8, 2017 | 01:22 PM
Lawrencew's Avatar
Lawrencew
im just beginning my re build of my 55 merc M100, was considering a custom chassis as I want to go with IFS, and a 4 link. Any suggestions would be appreciated as this is fairly new ground for me, thanks
Old Aug 8, 2017 | 02:33 PM
F1 Mike's Avatar
F1 Mike
A couple of questions: How much fabrication are you comfortable doing? And what's your budget? If you want to buy a 'bolt together' chassis you will be looking at some serious $$. The more you do yourself the more potential there is for keeping the dollar outlay to a minimum.
Old Aug 8, 2017 | 03:20 PM
Lawrencew's Avatar
Lawrencew
I'm ok welding together but don't have equipment to cut . Total truck build budget is $50,000cdn
Old Aug 8, 2017 | 04:24 PM
CharlieLed's Avatar
CharlieLed
TCI, Art Morrison, Fatman, The Roadster Shop, and the list goes on. Do some homework on the internet, just search on F100 chassis and you will have a number to choose from. You can spend from $6K to $30K USD or even more depending on how custom you wish to make the chassis. Good luck...
Old Aug 8, 2017 | 05:02 PM
highdesert55's Avatar
highdesert55
I added a TCI Custom IFS and TCI four link rear. It turned out nice but with all the time I spent taking out frame dents, rivets, cross members, and then truing, squaring, leveling, boxing my existing frame, I spent tons of time on it. I think i would seriously look at buying a complete chassis if I did it again.
Old Aug 8, 2017 | 05:35 PM
F1 coyote's Avatar
F1 coyote
I got mine through JW rodshop out of WI. all the mounting points were on point. All I had to do was cut the front bumper mounts off old frame and weld on to new frame so I can use the original bumper. Cab, bed and running boards all lined right up.
taagman
May 28, 2018 07:20 PM
WncLee
13
Apr 6, 2017 03:27 PM
oldracerjones
1961 - 1963 F100 Unibody
Jul 16, 2014 09:48 PM
McMatty
Jan 11, 2013 07:38 PM
rnelson664
Jan 14, 2007 07:55 PM
