6637 Alternatives?
Old Mar 18, 2010 | 09:15 PM
  #31
CobraGT40's Avatar
CobraGT40
My K&N Filter has let in a bit of dust....there's evidence of it in my intake tube. I ordered a Wix 6637 from Fleetfilter delivered for approximately $40. Does the AFE Washable filter keep the dust out ? ALL of it ? And will it attatch to the K&N Cold-Air intake tube ? If I can find a re-useable filter that keeps my intake free of any and all dust, I think it justifies the extra $...
Thanks !
Scott
Old Mar 19, 2010 | 01:13 AM
  #32
Neil64's Avatar
Neil64
Oil
Does the AFe come preoiled? I have some old K&N spray oil. Is that what is used? I assume that you also have oil the inside of the inverted cone?
Is this the same Pete's PreCharger that fits the 6637 or is it different? I have been using pantyhose as a precharger on my 6637 and maybe it is time to move up a notch!.....lol
Old Mar 19, 2010 | 02:26 AM
  #33
Stewart_H's Avatar
Stewart_H
Originally Posted by N V US Lawn Care
NVM...found it...$93 huh...holy crap...i think i'll go with the 6637...
Clay has it for $89 bucks. Riffraff Diesel: AFE "Big Boost" BHAF Washable Filter
Yes.
AFE uses their own oil formula. And you spray the inverted part of the filter the same way you spray the rest of the filter. On the outside.
The AFE Big Boost uses a different pre-filter. The one Pete makes for the AFE is inverted on the end to fit the inverted cone. The 6637 doesn't have the inverted cone on the end.
I had an AFE stage 1 on my truck, but pulled it when I added the 38R because the stage 1 couldn't keep up with the demand of the 38R.
The Big Boost has zero problems keeping up.
Stewart
Old Mar 19, 2010 | 02:53 AM
  #34
Neil64's Avatar
Neil64
Oil Analysis
Has anyone done a oil analysis while using the AFE? How about checked for dusting? I was a proponent of K&N prior to buying my truck and researching info on this forum. Now all of the K&Ns are now sitting on a shelf and I am back to using paper filters in every vehicle. I have read that AFE filters better but I want to make sure that the cotton doesn't get sucked or moved during high boost.
Also, does required boost increase for a certain speed when a filter is dirty or is it the other way around? In other words, with a clean 6637, on level road @ 70mph, truck makes around 5lbs of boost. Now truck makes 6-8lbs on the same roads @ 70mph. Would/could that be an indicator of a restricted filter? I have 16K on the filter driving on roads in Maryland. No dirt roads. Going to build a boost leak detector if all goes well this weekend. Only change is a rebuilt tranny and tq converter (which I am leaning towards as the cause). Truck ran normal boost before rebuild but it is possible the 6637 got wet as the tranny shop yahoos may have left the hood up while it was raining.
Thanks...
Neil
Old Mar 19, 2010 | 05:41 AM
  #35
bdrummonds's Avatar
bdrummonds
I had an oil analysis done 10K after getting the AFE. my silicone levels were at 4. With my old paper 6637 my silicone levels were at 5. I am having an UOA done in the next week or so, and the filter will have about 50K on on it. I will post up my findings, when the report comes back.
A clogged or dirty filter means less boost. Boost is the compression of air, by the turbo. If there is no clean air flow, the turbo has less air to compress, thus lower boost.
Old Mar 19, 2010 | 10:04 AM
  #36
Neil64's Avatar
Neil64
UOA
Thanks. I will wait for your UOA and if all is well, I'll be placing an order with Clay.
Thanks...
Mowing Man
54
Nov 27, 2021 05:45 PM
OldWoodsDiesel
Dec 21, 2012 08:42 AM
ALF1999
Jun 7, 2011 06:12 AM
Paladin921
Nov 14, 2010 09:32 PM
SSSimon
17
Aug 13, 2010 04:44 AM
