Front shock recommendations
Old Mar 14, 2010 | 10:44 PM
FallstonYJ's Avatar
FallstonYJ
Just had my new EX state inspected and found out I need new ball joints and sway bar links. I figured while I am "into it", this might be a good time to replace the front shocks as well.
It is a 2003 with 7.3 and 4WD. It is stock but at some point in the future I would like to add a 2" lift.
Any suggestions/recommendations would be appreciated!
Thanks, Tom
Old Mar 14, 2010 | 11:47 PM
Ex03AK's Avatar
Ex03AK
Check to make sure but I think the stock size Bilsteins will accommodate a 2" lift.
Old Mar 16, 2010 | 01:15 AM
wallz's Avatar
wallz
I went with the rancho 9000's, and when I replaced the stock springs with v and b codes (resulting in a 2" lift) the stock 9000's worked fine.
With the heavier dsl motor you might want to look into the heavier x or w codes to still come out with 2" lift.
Old Mar 16, 2010 | 10:13 PM
FallstonYJ's Avatar
FallstonYJ
Ex03AK & wallz; thanks for your time & input!
Based on a recommendation from a good friend of mine who also happens to be the manager of a large repair facility, I went with Reflex shocks from NAPA; (Monroe). I haven't installed them yet but I will post up again after I have them on the EX for a little while and let you know what I think.
Thanks again!
Old Mar 17, 2010 | 09:01 PM
Ex03AK's Avatar
Ex03AK
Thanks again!
I have the Reflex on mine. Huge improvement over stock! I have never ridden on anything else in an Excursion so I have nothing else to compare them to.
Stew
Tom Callan
Mar 27, 2015 03:18 PM
tom from mass
Jan 17, 2014 12:53 PM
nascar_20
Nov 15, 2013 06:35 AM
mayerst1
1983 - 2012 Ranger & B-Series
Apr 16, 2006 06:31 PM
TomF
Jun 4, 2003 11:42 AM
