Vibration over bumps and high-speed curves
Hello all,
Long time reader, first time poster.
'99 Ranger, 4x2, 3.0L
I would get a lot of vibration over bumps and high-speed curves. The steering wheel would shimmy so I narrowed the options to the front-end. I found a bad shock on the right front so I replaced both front shocks. This made a big difference but the high-speed vibration is still there. I suspect the bad shocks threw out the alignment or the wheel balance. Maybe the bad shocks caused some uneven wear on the tires. I will try to swap the front and rear wheels to see if the problem is in the wheels or tires. Any ideas ?
Many thanks,
Tom
Many thanks,
Tom
Here is an update:
After rotating the front and rear tires, the steering wheel did not shimmy anymore, although a vibration could still be felt.
During the rotation, I noticed some slight cupping on the inside of the former front tires; no doubt a direct result of the bad shocks.
I had the 2 rear tires (formerly in the front) balanced and had the alignment checked. The alignment was good.
I went ahead and replaced the rear shocks to keep an even wear on the tires.
So far, the truck is riding smooth at highway speeds.
sammie0126
09-11-2012 09:16 PM
jas88
05-15-2012 06:06 PM
sunogbahay
19
03-18-2011 01:49 PM
subcoolerlll
07-22-2009 12:04 AM
kenneBF250V10
1999 to 2016 Super Duty
25
05-15-2008 07:48 AM
