74 f250 4x4 power steering problems/questions
Old Mar 14, 2010 | 07:48 PM
breedo99's Avatar
breedo99
Just recently purchased the truck and have been doing a little work on it. The truck has factory power steering but wasnt working when I got it mainly because there was no fluid. Added fluid and the pump mad grotesque noises fluid started basically pouring out of some sort of shock thing on the front axle???? Almost like a steering stabilizer but had power steering lines running to it. Already priced the pump ($40) but have no clue what the shock thing is or where to get it. Can anyone help me with this?????????
Old Mar 14, 2010 | 08:05 PM
montana_highboy's Avatar
montana_highboy
You have the power-assist steering setup, the parts are available but are VERY expensive, if the system's totally thrashed you're better off just doing the 78/79 integral power steering upgrade, it seems at the very minimum you need new seals for the hydraulic cylinder ($40) you need to cut the cylinder open to install the seals then weld it back together.
Old Mar 14, 2010 | 08:14 PM
breedo99's Avatar
breedo99
What parts do I need to do the upgrade and how do I do it? Also how much am I looking at?
Old Mar 14, 2010 | 08:34 PM
montana_highboy
https://www.ford-trucks.com/forums/8...-steering.html
Old Mar 15, 2010 | 09:16 AM
breedo99's Avatar
breedo99
anybody know anthing about redneck rams out of texas? supposedly they do anything from rebuilds to complete hydraulic assist kits. my buddy suggested them for the power steering problems
Old Mar 15, 2010 | 09:31 AM
WyoExplorer's Avatar
WyoExplorer
exactly why I still don't have steering, looked like a steering stabalizer, it's a Power Steering Cylinder and it's almost $500
Old Mar 15, 2010 | 06:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1974 F250 4x4 power steering problems/questions.
1974 F250 4WD's used two totally different types of Power Assist P/S, GARRISON & BENDIX. The parts do not interchange!
All 1973 F250 4WD's, 1974 F250 4WD's before serial number T80,001 used GARRISON P/S.
1974 F250 4WD's from serial number T80,001, 1975/77 F250 4WD's (High Boy's) used BENDIX P/S.
The serial number is the last six digits of the VIN.
Ford sold P/S seal kits for both the control valve and the ram cylinder, also the bushing kit to mount the ram to the frame.
These kits are obsolete, but a few can still be found at Ford Dealers, obsolete parts vendors.
The last time I looked, there were several new ram cylinders available. These are also obsolete.
Old Mar 15, 2010 | 06:23 PM
breedo99's Avatar
breedo99
Expensive I'm sure
Old Mar 15, 2010 | 06:28 PM
breedo99's Avatar
breedo99
My serial number is in the 40000s
Old Mar 15, 2010 | 06:31 PM
NumberDummy
Expensive I'm sure
Not necessarily, it depends....
Since the parts are obsolete, the Ford Dealers can no longer return them to Ford...so are STUCK with them.
Usually Ford Dealers sell obsolete parts at...or below the last MSRP, or at their original net cost. One Ford Dealer in AZ has 1000's of obsolete parts, sells them below their original net cost.
Obsolete parts vendors are in the business of selling obsolete parts, so the price is usually much higher than the last MSRP.
A member needed a Race Track moulding for the right lower quarter panel (bed side) that had the accessory tool box. I found exactly one...at dealer in KS.
He bought (stole!) it for $38.40, the original MSRP.
Old Mar 15, 2010 | 06:46 PM
breedo99's Avatar
breedo99
Any idea of anybody that might have it or who to call?
Old Mar 15, 2010 | 07:01 PM
NumberDummy
1974 F250 4WD w/Garrison Power Assist P/S (before serial number T80,001).
D3TZ3A540D .. Ram Cylinder-Use w/Garrison P/S / Obsolete
No Ford Dealer or obsolete parts vendor has any.
D3TZ3C590A .. Ram Cylinder Bushing Mounting Kit / Available from Ford.
MSRP: $39.22 // FTE Ford Dealer Parts Dept sponsor PARTSGUYED.COM price: $28.24.
You can also order it from your local dealer, but I doubt you will get this discount price.
The only LA (Louisiana) Ford Dealer that has it in stock, is: SHETLER-CORLEY FORD in Crowley = 337-783-4600.
D3TZ3A764A .. Ram Cylinder Seal Kit-Use w/Garrison P/S / Obsolete
RED TAYLOR FORD in Corning AR has ONE = 870-857-3518.
RAY MOTOR CO. in Hillsborough NC has ONE = 919-732-8118.
DOTTS MOTOR CO. in Clearfield PA has ONE = 814-765-9681.
GRIESEL MOTOR CO. in Okarche OK has ONE = 405-263-7242.
WESLEY OBSOLETE PARTS in Liberty KY has FOUR = 606-787-5293.
CARPENTER OBSOLETE PARTS in Concord NC has SIX = 704-786-8139.
Old Mar 15, 2010 | 07:36 PM
breedo99's Avatar
breedo99
I will...thanks a lot
Old Mar 16, 2010 | 08:43 AM
73 hi-boy 428 fe's Avatar
73 hi-boy 428 fe
You can get one from LMC truck parts. It is like $225.00 or so plus a core charge. Mine works great from them.
Old Mar 16, 2010 | 08:54 AM
breedo99's Avatar
breedo99
thanks for the help guys! i will check out my truck and see exactly what i need. think i will either rebuild it or get one from lmc.
