Computer Chips & Tuners
89 4.9 EEC-IV question
Old Mar 14, 2010 | 09:12 AM
84Fordvan's Avatar
84Fordvan
I am going to be putting an M90 on my 4.9, running 5 PSI boost. I have read that the EEC-IV ecu will handle boost up to 8 PSI, is this correct? My ecu is out of an 89 F-150 with a manual tranny, currently running it on my 84 E-150 with a brand new engine. IIRC, there is a guy on this site who should've had the same ecu and ran a turbo on his. I tried Megasquirt, but couldn't get it to behave like it should.
Old Mar 14, 2010 | 11:47 AM
Conanski's Avatar
Conanski
Originally Posted by 84Fordvan
I am going to be putting an M90 on my 4.9, running 5 PSI boost. I have read that the EEC-IV ecu will handle boost up to 8 PSI, is this correct? .
This ECU can't "handle" any boost since it's not designed for a motor with positive manifold pressure, but that doesn't mean you can't use it for the application. What is required is an FMU to raise fuel pressure in line with blower boost and an ignition box that either automatically removes advance with input from a knock sensor or one with manual retard control.
MBAGDON
Electrical Systems/Wiring
Mar 17, 2025 04:47 PM
PyroBob
Apr 15, 2005 07:22 AM
proteks
Jan 3, 2005 08:11 PM
Oscar Meier
Sep 16, 2003 10:01 PM
stone
Jan 25, 2001 12:36 AM
