Trouble Codes for EEC-IV?
Old Jan 14, 2001 | 05:11 PM
stone's Avatar
stone
I own a 1986 F-150 2x4 300-6. According to the sticker under the hood my truck has an EEC-IV computer in it. I have been having a TON of trouble getting my truck to run/idle/start/etc. and I've finally got everything tuned, but it still isn't right.
Does anyone know if/how I can get the Trouble Codes for an EEC-IV? Help and directions would be greatly appriciated!
Thanks,
Stone
Old Jan 14, 2001 | 06:39 PM
carlos57's Avatar
carlos57
I have been fighting an intermittent problem with starting and dying. Like turning the key off and back on. Sometimes it dies for 3min, sometimes for 3 hours but usually just a couple of minutes or on and off as I am driving but that was back in the 105 to 108 deg temps back in late August.
Finally it refused to start yesterday and nothing I can do will get it to go. Thank God! I sure hope it's broke and the garage can fix it now. Was towed today and hopefully will continue to refuse to start and when they get it fixed I'll post whatever it was.
It doesn't seem to like high heat or humidity. I have put on a rebuilt distributor, cap, rotor, wires, plugs, map sensor, temp sensor, EEC relay, fuel pump relay, alternator (lost that in Kansas), fuel filter and I am sure I am forgetting something.
Carlos
Old Jan 14, 2001 | 08:20 PM
stone's Avatar
stone
I hope everything works out. You seem to be having the same type of problem I'm having. Please post the solution when you get it, I'm sure I could benifit from it too!
Thanks,
Stone
Old Jan 15, 2001 | 09:57 AM
towing_joe's Avatar
towing_joe
Stone,
I found this link at one of these message boards. I hope it helps.
http://www.dalidesign.com/hbook/eectest.html
It tells you how to get the codes and more importantly it has a listing of the codes.
Old Jan 15, 2001 | 04:47 PM
stone's Avatar
stone
Thanks Towing Joe!
Big help, just what I was looking for. I've yet to try the jumper, and get the codes out, but at least I know what to look for.
Stone
Old Jan 23, 2001 | 10:36 PM
carlos57's Avatar
carlos57
Well the local Ford dealer assures me that they believe that it's finally fixed. Some of you may remember that I had an erratic miss and/or dying. Similar to most folks problems. Well it finally quit and had to be towed. They have had it for several days to diagnose and determined that there was a problem with the wiring harness. So we had them replace it. At least the part of it around the motor and not really sure how much that really is. Lot's of new plug ends etc. They have had it for a couple of days to hose down and see if it would act up again but seems fine for them. I go get it back tomorrow. There may have been less expensive ways to do this and maybe aftermarket parts would have been better, but once I got started replacing with Ford parts I kept with it, so to with the wiring harness. Looks like with the towing it is going to be near $500 which I will get the towing back. A bunch of money, but if it fixes it, worth every penny.
Carlos
Old Jan 24, 2001 | 01:02 PM
brown 4x4's Avatar
brown 4x4
>heat or humidity. I
>Carlos
Carlos, your problem sounds like a bad TFI module. The early models had them mounted on the distributor and fail often due to heat. This is a common problem with early computerized Fords.
1986 F-150 4x4 300 I6 NP435
Old Jan 24, 2001 | 07:43 PM
carlos57's Avatar
carlos57
Well, picked up the truck. Noticed right off the bat that it started, high idled and then dropped to low idle, about 800 rpm, just like in the old days. Ran smooth all the way home. The intermittent miss that I always get about when the thermostat opens was gone. Didn't have a problem. Only time will tell if they really got it cured.
With the wiring harness they also replaced the ignition module again, just in case. Fourth one that has been on since August. The wiring harness unit is just the portion on the drivers side of the motor and plugs into the connections mounted on the inner fender and the various points on the engine. This thing seems to be running as good as my 1988 did and it ran real well.
Will let you all know if I have any more trouble. Oh yeah, never any bad codes to download with any of my problems.
Carlos
1991 F-250 XLT 4x4 I6 300ci, ZF 5sp/overdrive, 145000 miles
Old Jan 25, 2001 | 12:36 AM
PAUL_2's Avatar
PAUL_2
mike L
Jan 23, 2010 10:08 AM
carpe_diem
Nov 11, 2003 09:03 PM
CNTHOR
Aug 24, 2002 07:50 PM
Mark Kovalsky
Jan 5, 2002 07:27 PM
