48 hood latch question
Old 03-12-2010, 11:32 PM
ghart's Avatar
ghart
ghart is offline
been working on getting some body things straightened away. i dont think the PO hooked the hood latch up quite right. i think the notch on the end of the handle should hook onto the tab that the spring is pushing against. can anybody plz confirm this? a pic of your setup would be helpful. thx!
Old 03-13-2010, 12:54 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is online now
Received 2,124 Likes on 822 Posts
Here's the only picture I have of the latch:
Here's a blow up from the parts catalog:
Hope this helps.
Old 03-13-2010, 09:41 AM
mtflat's Avatar
mtflat
mtflat is offline
No, it's correct as is. When you pull the handle it pushes against the tab. The plate the tab is connected to pivots - pin is under the spring. As it pivots the finger on the left side moves to the front, releasing the hood pin.
Old 03-13-2010, 02:11 PM
bobj49f2's Avatar
bobj49f2
The one part I see missing is the spring that the pivot rod goes through. This might be causing a problem.
ghart
28
07-01-2018 02:22 PM
ghart
09-01-2016 02:58 PM
ghart
08-23-2016 03:27 PM
ghart
08-21-2016 10:45 AM
Wayne Waldrep
21
08-03-2014 05:25 PM
Quick Reply: 48 hood latch question
