Flathead Alternator Conversion - Wide Belt
Old Aug 18, 2016 | 03:45 PM
ghart's Avatar
ghart
I'm sure this is probably common knowledge to most of you guys, but I thought I'd share/document my first real upgrade to my 1949 F-1. I didn't feel like the generator was putting out a very adequate charge and I wanted to clean up the engine bay a little bit, removing the voltage regulator and respective wires. So I decided to make the jump to a GM 1-wire alternator.
The (small) problem is that my flathead V8 is of the wide pulley (5/8"), two belt variety. Almost all alternator conversion brackets that I found required you to grind off part of the alternator and a mounting spacer in order for the belt to line up properly. Why grind down perfectly good, brand-new parts, right?
Enter the Alan Grove bracket, model 242. It's made specifically for our wide-belt systems without any modifications. I also purchased a 5/8" pulley from Speedway Motors. Lastly, I picked up an alternator from JEGS. All told, the parts came right to $200 with shipping.
Installation was a breeze. Swapping the pulleys was made easy by using an impact wrench. Replacing the generator with the alternator was straight-forward. Just a little tight with the fan still in place.
The parts:
The alternator and bracket assembled:
Installed (disregard the fan not being hooked up - the belt fell apart and I had to order a new one):
Old Aug 18, 2016 | 04:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Good info! Were you already 12v, or is it a 6v alternator?
Old Aug 18, 2016 | 04:28 PM
ghart's Avatar
ghart
The PO did a basic 12 volt conversion. Basically, I think he put in a 12 volt battery and then disconnected all the gauges. I think he might have swapped the light bulbs, as the taillights seem to work fine. I'm not sure if he ever changed or modified the regulator for 12 volts.
I was considering using voltage reducers and hooking the original gauges, but I just snapped a post off the ammeter. Not quite sure what I'll do about that. I see new ones are available on ebay, but each gauge is about $84 (including S&H) - ouch! I might just go with aftermarket gauges... we'll see
Old Aug 18, 2016 | 05:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I've seen stock ammeters as low as $5 used on eBay, and NOS new for less than $84. Not sure what you mean by "one of the posts" on the ammeter, it has a loop?
Old Aug 21, 2016 | 10:45 AM
5851a's Avatar
5851a
The stock gauges will work if you swap wires from post to post and add a constant voltage regulator from a later ford with 3 gauges like a mustang. The aftermarket has electronic ones that people seem to like. The P series trucks (70"s UPS) had the same gauges with different graphics and I have swapped them. Up into about 1987 Ford still used a regulated (CVR) gauges that operated on about 6 volts. The reason for the post to post swap is going from 6 volt positive ground to 12 volt negative ground.
Instrument Voltage Regulator This gives you an idea but over my head. They have them built on the bay or elsewhere.
Bob's49
Mar 9, 2018 12:56 PM
California Codfish
Dec 4, 2012 06:18 PM
OregonJen
1947 and Older Ford Trucks
Feb 12, 2012 11:36 AM
WarOzz
Jul 31, 2010 05:01 PM
aj197816134
Apr 15, 2007 10:33 PM
