Saftey neutral switch
Old Feb 17, 2012 | 04:53 PM
rangergirl94's Avatar
rangergirl94
I swapped out my bad e4od in my 93 f150 for a good one outta 95 150 but the saftey neutral switch plug is different can I bypass this or any other options?
Old Feb 17, 2012 | 05:32 PM
White 97 xlt's Avatar
White 97 xlt
swap the one off of the 93 trans onto you fresh trans
Old Feb 17, 2012 | 05:42 PM
rangergirl94
I crossed the solinoid to start it and the dust cover is hitting the flywheel????
Old Feb 17, 2012 | 05:56 PM
White 97 xlt
That E4OD will NOT shift properly if the "safety" switch is not connected.. (All connections.)
Old Feb 17, 2012 | 09:22 PM
rangergirl94
How do u remove the saftey n? I took the two little bolts out and that shifter arm does it just slide off ? It seems stuck I dont wanna break it. Its only plastic
Old Feb 18, 2012 | 05:12 AM
Lazy K's Avatar
Lazy K
The one on the `95 trans will be the updated one so I would keep it. You should be able to get an adapter plug at a parts store to enable you to connect the plugs.
Before you retighten the bolts, shift the trans to neutral and align the scribe marks on the NSS, then tighten the bolts.
Old Feb 18, 2012 | 06:50 AM
rangergirl94
Whats the diff, in the updated one? Could someone plz get me a part number for the adapter plug the local auto parts store is clueless
Old Feb 18, 2012 | 07:54 AM
rla2005's Avatar
rla2005
Ford changed the design of the connector on the MLPS to eliminate problems with moisture/dirt/grime/etc. The inside pins are the same, it's the overall design of the connector itself. If you purchase a MLPS through Ford/Motorcraft it usually comes with the new connector that plugs into it. It has an instruction sheet for how to push out the pins on your old MLPS plug and install them in the new one. I do not know if any of the below plugs have that included.
These are for the plug only:
Standard Motor Products: S798
Airtex/Wells: 1P1165
AC Delco: PT1979
Old Feb 18, 2012 | 07:37 PM
rangergirl94
According to autozones computer the adapter plug has to be wired into the harness so idk?
Old Feb 19, 2012 | 02:22 PM
rangergirl94
Can anyone tell me how to remove it off my old trans without breaking it? Please
Old Feb 19, 2012 | 03:35 PM
Lazy K's Avatar
Lazy K
To get the NSS off you have to remove the manual shift lever. On newer transmissions there is a nut on the outside that you can remove and then slide the NSS off.
On older transmissions you have to drop the pan and remove the nut from inside the case and slide the shaft out with the manual shift lever.
Old Feb 19, 2012 | 04:40 PM
rangergirl94
Can I put my 93 nss on the 95 trans without removing the lever from inside the trans? I have no problem removing that lever from the old tranny just hope I dont have to on my new trans to install it
Old Feb 20, 2012 | 06:52 AM
Lazy K's Avatar
Lazy K
Unfortunately if there is no nut on the outside of the shift shaft then you will have to drop the pan and remove the nut on the inside of the shaft. The manual lever and shaft will then slide outwards and the NSS can then be removed. The shift detent lever and parking pawl lever are on the shaft on the inside of the case so note how they are positioned before withdrawing the shift shaft. Fit the new NSS and slide the shaft back in, refit the linkages and tighten the nut.
Old Feb 20, 2012 | 04:40 PM
rangergirl94
They dont offer a 93 nss I have to hot wire a new plug
Old Feb 20, 2012 | 08:37 PM
rangergirl94
I changed it to the new style it starts still shifts wrong and now it wont crank if its in neutral only park? Please help its my dd
