1978 - 1996 Big Bronco
neutral saftey switch
Old Mar 12, 2006 | 05:06 PM
jeffschreck's Avatar
jeffschreck
Question neutral saftey switch
I just purchased a 1994 Bronco and am having trouble finding the neutral saftey switch on e40d tranmission any help would be greatly appreciated. Thanks
Old Mar 12, 2006 | 08:06 PM
greystreak92's Avatar
greystreak92
There is no neutral safety switch. The sensor is commonly referred to as the MLPS (Manual Lever Positioning Sensor) and it not only tells the computer when the transmission is in neutral but every OTHER gear as well. The fully electronic E4OD requires this setup so that the computer "knows" what the transmission is supposed to be doing. The MLPS is located on the driver's side of the tranny at about the midpoint fore-to-aft. If you need to replace it, you will end up with a newer version that will require changing the connector on the wiring harness. Don't worry though, Motorcraft includes the new connector with the MLPS.
Writemcowboy
Apr 14, 2014 09:02 PM
rangergirl94
16
Feb 21, 2012 07:21 AM
stoney720
Apr 19, 2011 11:26 AM
Voodoo ChildVood
Mar 16, 2010 06:46 AM
Johnny1369
Electrical Systems/Wiring
Jul 19, 2002 08:08 PM
