When replacing the diff fluid is the gasket reusable?
Old Mar 12, 2010 | 03:08 PM
02GrayPowerStroke's Avatar
02GrayPowerStroke
And since we are on the subject what oil is recommended? And how much does it need? Also does it need the track lock additive? And does it need it for the front?
As far as the gasket goes, if it not reusable does it use a gasket or does it just use RTV?
Old Mar 12, 2010 | 03:13 PM
rickatic's Avatar
rickatic
Synthetic in the rear-90/145 and traction additive if you have limited slip and no gasket just RTV. Front takes 85/90, no additive and again no gasket. I used Mobil One in the rear and Valvoline in the front
Regards
Old Mar 12, 2010 | 03:16 PM
02GrayPowerStroke
Originally Posted by rickatic
Synthetic in the rear, traction additive if you have limited slip and no gasket just RTV
Regards
Its been a while, are the traction activities a Ford only item?
Thanks for the reply, how many bottles will they hold?
Old Mar 12, 2010 | 03:47 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Here's some good stuff on that....from the 6.0 tech folder sticky at the top of this forum:
https://www.ford-trucks.com/forums/3...d-in-tech.html
http://www.guzzle7pt3.com/fdiff.php
http://www.guzzle7pt3.com/rdiff.php
Old Mar 12, 2010 | 04:06 PM
rickatic's Avatar
rickatic
I just did mine two weeks ago. To fill it to plug level took around 3 quarts IIRC
Old Mar 12, 2010 | 04:17 PM
02GrayPowerStroke
Originally Posted by SteveBricks
GREAT links! Thanks, I believe thats all the info need. Bookmarked the pages.
Thanks again, reps to ya.
Old Mar 12, 2010 | 10:54 PM
98SurplusExpy's Avatar
98SurplusExpy
Don't over fill either ... spec says 3.45 qts & I tried to cram that in there & ignored the "level below the fill hole" spec.
Pinion seal leaked and slung oil everywhere afterwards. I had to pop the fill plug off & take some fluid out until the level was in spec.
Best thing to do is cut some small strips of paper, bend them in a "L" shape, and use these to check the level depth below the fill plug.
Old Mar 13, 2010 | 12:29 AM
cartmanea's Avatar
cartmanea
Regards
If you're going to give advise, make sure you have the correct info. Rear takes 75w-140 synthetic, front takes 80w-90 and most use a 75w-90 synthetic. The rear may or may not need the friction additive, depending on which fluid you use. With Royal Purple and some other high grade synthetics, you don't need the additive. The best advise is to add none, then add half bottle of the modifier at a time if you experience chatter in corners, allowing time for it to work into the clutches before adding more. Spec is around 3.5 quarts, so you'll need to buy 4.
Old Mar 16, 2010 | 02:00 PM
02GrayPowerStroke
Holly Synthetics BatMan!! Crap its gona costs $80 to change out the diff fluid! Can I just use conventional oil?
Old Mar 16, 2010 | 02:24 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Yeah...I used Mobil1 75w-140 (LS) doesn't require friction modifier...about $17 a qt. and I changed the cover to the '08MY cover from FordPartsGuy for $45 ...in the end it cost me $155
Old Mar 16, 2010 | 02:56 PM
cartmanea's Avatar
cartmanea
Conventional doesn't stand up to the pressures as well. You could probably get away with a similar weight conventional oil, but it would shorten the service interval. Just do it right the first time and forget about it.
Old Mar 16, 2010 | 02:58 PM
02GrayPowerStroke
Dangit. I knew some one would say that. Just have to same up my Pennys.
Thanks for the help!
lupuseven
Dec 5, 2013 12:27 PM
powerstroker100
May 5, 2013 01:53 PM
powerstroker100
Jun 3, 2010 09:14 PM
scoosty
Jul 23, 2001 09:05 PM
