Is this normal?
Old Mar 10, 2010 | 10:45 PM
starmilt's Avatar
starmilt
The thing on your IP with the little rod is your fast idle solonoid. I do not even use mine except when it is cold. I know it isn't right but mine always started fine for 20 years without it and old habits are hard to break. lol
Your cold start advance is inside the IP it actually advances the the timing until the motor warms to 112 degrees and the same temp switch controls it and the fast idle solonoid so they shut off at the same time.
The first thing I would check is your glow plugs, info for the procedures are in the sticky at the top of the page.
A puff of smoke is normal at startup especially in the winter, but not a cloud and it should clear up fairly quick. Running ragged and vibratiing is a miss caused by one or more cylinders not heating as fast as the others, glow plugs are the most common culprit, but even with a bad glowplug that cylinder should start hitting pretty quick.
A dribbling injector can cause it as can low compression in the cylinder.
Old Mar 10, 2010 | 11:38 PM
idahodisco's Avatar
idahodisco
Thanks for clearing that up for me starmilt, first thing first I will look at my glow plugs. I may be making it bigger than it is coming from a gass to a diesel. I alway over obses over my trucks!
Old Mar 11, 2010 | 07:46 PM
idahodisco's Avatar
idahodisco
Ok so I looked at every Glow plug today and are are good! But I did find a broke " COLD IDLE TIMING ADVANCE SOLENOID TEMP SWITCH " is what the guy from Ford called it, so if I fix this all my problem should go away right?????? I thought some one said dont need it?
jrpworkemail
Jun 27, 2014 09:20 AM
spin498
1997 - 2003 F150
Jan 30, 2013 11:17 PM
ltl_jrw
15
Nov 3, 2011 11:58 PM
Diesel_Dirk
Feb 19, 2009 06:21 PM
mgm415
Dec 10, 2001 06:06 AM
