Is this normal?
Old Mar 10, 2010 | 07:04 PM
idahodisco's Avatar
idahodisco
Is this normal?
So I just got the truck and I dont know if this is normal or something wrong? When I start it in the morning I turn the key and wait for the light to go off it takes about 5 to 6 cranks and a large cloud of smoke shoots out and it runs like crape for about 25 sec a lot of movement under the hood! After the 25 sec of running rough it smooths out and is real smooth running. FYI its about 30-40 deg out!
91 F250 idi 175,000 miles
Old Mar 10, 2010 | 07:22 PM
LCAM-01XA's Avatar
LCAM-01XA
how long does the WTS light stay on? Should be at least 15 seconds...
Old Mar 10, 2010 | 07:27 PM
idahodisco's Avatar
idahodisco
I would say 15 or less in the morning! That's real close to it.
Old Mar 10, 2010 | 07:31 PM
starmilt's Avatar
starmilt
You may have a leaky injector. Is your cold start advance working.
Old Mar 10, 2010 | 07:34 PM
64F260's Avatar
64F260
Might also have a few bad glow plugs.
Old Mar 10, 2010 | 07:35 PM
idahodisco's Avatar
idahodisco
I dont know how can I test my cold start advance?
Old Mar 10, 2010 | 07:54 PM
LCAM-01XA's Avatar
LCAM-01XA
I'm thinking one dead glowplug.
idahodisco's Avatar
idahodisco
Is this how you test Glow Plugs? Pull the cap off the glow plug and stick one lead from the tester in it and the other lead goes on the top of the glow plug? If its in the .5 to 2.0 range than its good?
Is that right
Old Mar 10, 2010 | 07:58 PM
starmilt's Avatar
starmilt
If the timing is right it will rattle for awhile when you first crank it and quieten down when the motor reaches 112 degrees, you can crank it cold and pull the wire off the ip and hear an audible change.
Another thing to check is when you first crank it and get that cloud of smoke is to smell it and see if it has a fuel smell or a sweet smell.
Old Mar 10, 2010 | 09:10 PM
idahodisco's Avatar
idahodisco
So it normal every ones trucks do that too! unless I have a sweet smell in my smoke?
Old Mar 10, 2010 | 09:28 PM
WarOzz's Avatar
WarOzz
Yea it should rattle but it almost sounds like your describing all the cylinders not firing up together. For sure check the gp's and cold start advance. When you turn on the key and hit the peddle to the floor you should hear that advance click. Quick check on gp's is hook a test light to positive cable, pull connector off gp and touch probe to end of gp. If light lights up bright the gp is good.
Old Mar 10, 2010 | 09:57 PM
idahodisco's Avatar
idahodisco
So turn key to the # two position but not start and then push peddle to the floor then I will hear the advance click? If no click then bad cold start advance.
Thanks Warozz
Old Mar 10, 2010 | 10:11 PM
starmilt's Avatar
starmilt
NO that is the fast idle solonoid that comes on when you mash the pedal, and when you turn the key on you will be hearing the fuel solonoid click. You need to unplug your cold start advance and you will hear the sound of the motor change. I highly doubt the cold start advance is your problem as they will usually start abd run just as good with out it as with it, but it wouldn't hurt to check it.
Old Mar 10, 2010 | 10:22 PM
idahodisco's Avatar
idahodisco
I think I get it so this is like a Choke on a carb if I unplug the cold start advance it will idle a little slower! RIGHT also is that the thing that sits on the IP has a pin that almost touches the thottle arm?
Ya I do hear the clicking after my WTS light goes off!
Are we on the same page starmilt?
FYI First thing tomorrow GP test I actualy picked one up today for the glove box its a mastercraft!
Old Mar 10, 2010 | 10:41 PM
dyoungen's Avatar
dyoungen
If the WTS light stays on for the 10 to 15 seconds, it sounds like your glow plugs and controler are working ok. If you have a dead plug the time will drop to 2 or 3 seconds. If you smell something sweet in your exhaust that sounds like coolant in the cylinders being burned. Not good!
