Won't stay running
Won't stay running
about 3 weeks ago this problem started, first thing in the morning it will fire right up and then just die like turnning the key off. Then if I turn the key off and then back on and leave it on for about about 60 sec it will fire up and stay running but a little rough then smooth out. HELP
On the 2nd attempt is almost always fires right up, a few times it took a little to get it started, as for the oil gauge I never really noticed.
Read this thread. I had the same issue. It's your LPOP. Order a new one. Riffraff Diesel: Melling LPOP. Easy to replace. Get er done before it gets colder out.
Can the OP confirm by checking the HPOP reservoir immediately after it dies but before attempting to start the second time?
A weak LPOP should result in long crank times after initial stall, a stand pipe failure will almost always start quickly, I would check the HPOP reservoir when completely cold then immediately after stall I'll bet it's drained back some while sitting but fills right up during the run and crank cycle!
It's the LPOP, I promise.
It's a really good possibility! I have just been burnt by that standpipe a couple of times & and it's a really easy look in when cold for drain back, not really how Monty can do it ^so well! (lacking opposing thumbs and such) but ^^^^^he assures me it's worth a look but at $80.00 for a pump it's almost worth it IMHO to replace them at 150k anyway just as a preventative maint item!
Jim & fat Monty
Jim & fat Monty
