General Automotive Discussion
Air jacks
Old Mar 10, 2010 | 06:20 PM
rckslash2010's Avatar
rckslash2010
Air jacks
I've heard a few people mention air jacks. I've never seen any at the stores.Does anybody know anything about them? I was thinking that I could put an air hookup on the end of them cheap ones, where that nut is that you unscrew to release the pressure. Wouldn't that be cool? Just turn the valve and blow some air in there to raise the jack? Am I just thinking crazy, or is there someway that I could do this?
Old Mar 10, 2010 | 09:17 PM
Ford_Six's Avatar
Ford_Six
Air pressure isn't enough to lift a vehicle with a trolley jack. There's a few types of air jacks, the most common is a hydraulic bottle jack that has an air motor driving the pump. Another type uses the air directly, but they have a quite large cylinder and also leak down.
Old Mar 10, 2010 | 09:28 PM
*2fords*'s Avatar
*2fords*
I have one of those air hydrolic bottle jacks. It's 12 ton, and it has come in handy several times when used tolift and level out old houses. I got on Ebay a few years ago, I think I paid aroud 50.00.
Old Mar 11, 2010 | 06:24 AM
rckslash2010
So they do make them. The reason I asked is because I'm installing an air compressor in my truck, and thought it would be nice to keep one in the truck. I'm using a little 2 ton floor jack now, it's small enough not to take up a lot of room. But it sucks pumping it up.
Old Mar 11, 2010 | 12:51 PM
Lazy K's Avatar
Lazy K
http://www.harborfreightusa.com/usa/...submit=find+it Here are some examples.
Old Mar 11, 2010 | 04:44 PM
first today's Avatar
first today
How about this? Titan 3 Ton Exhaust Air Jack Jeff's bronco graveyard sells them.
Old Mar 11, 2010 | 07:07 PM
rckslash2010
Harbor freight doesn't list any prices, I'll call the store in Duluth tomarro. There the closet one. They've got a 25-50 ton floor jack that weighs 176 pounds. Imagine throwing that around the driveway. That 12 ton bottle jack would work for me.
That pillow jack thing that hooks up to your exhaust is a good idea. Looks like it would work pretty good. I wonder how much room it takes up.
Old Mar 11, 2010 | 07:25 PM
first today
If I remember correctly, it collapses to one inch and is 12 or 16 inch diameter. I think it would slide under the seat with no problem.
Old Mar 11, 2010 | 10:23 PM
*2fords*'s Avatar
*2fords*
I said mine was 12 ton, but I guess I was wrong. This one looks like mine
NAMEBRAND 20 TON AIR OVER HYDRAULIC JACK MODEL 95553 - eBay (item 360242362980 end time Mar-17-10 13:30:24 PDT)
This one is 12 ton, and doesn't look like mine at all.
Blackhawk Automotive Air/Manual Hydraulic 12 Ton Jack : eBay Motors (item 360241261065 end time Mar-16-10 14:09:57 PDT)
