How to remove the hub nut on an ATV
Hello guys, I need some ideas to get a hub nut out off my ATV. Basically, it’s a sports ATV and rear axel is bent. I put some penetrating lube etc…the right side just came off but the left one is not moving at all. The wheel starts to turn/slip (with one person sitting on the ATV with breaks on) with 2 foot breaker bar! Not sure what kinda of monumental moron installed this. I need to come up with some sort of tool to stop the axel shaft and hub from turning. Any ideas? The axel nut is 36 mm and I spent quite a bit on tools to take this off, so, I’m trying my best to not take it to a dealer.
Air impact not only imparts a 'twisting' motion, it 'hits' like a hammer to move/tighten/loosen a bolt/nut.
Hence. . . IMPACT.
(At least that's how it was explained to me.)
Suggestion: Place the wrench/breaker bar onto the nut, and have the breaker bar set-up in such a way that you can 'stand' on the bar, and use your full weight on it.
Have someone hold/support the wrench, then give it a quick 'pounce' with your foot. Kinda/sorta like trying to kick-start an old Harley. That MIGHT bounce the nut loose.
- OR -
Get a piece of steel (galvanized or 'black' pipe) and put over the breaker bar. You'll compound your leverage.
BE CAREFUL!!!!! I watched a guy SNAP some head bolts doing this.
USE CAUTION!!!!!!!!
Thanks All, I FINALLY got the bolt off on my own!!!!
I devised a plan, I took the bumper jack from my Jeep (it's 48 inches long metal rod) and you know it has holes that runs through the length? Well, I bolted the top end hole on to the wheel hub. Parked my other ATV on the jack’s bottom end. Started with the monkey business of standing and jumping on the breaker bar….My wife says, Dinner is ready and I should be getting back. But I wrench on…no luck for another 30 minutes. Finally my wife had it, she comes to the garage and looks at me jumping and getting frustrated. I decided to walk her through what I was doing and stood on the bar, bamp, it came loose! Damm you SOB NUT.
