speedometer gone crazy
Old Jan 22, 2003 | 08:23 PM
Wishbone's Avatar
Wishbone
Question speedometer gone crazy
My wife's rig is 96 windstar. The speedometer has started to jump around at speed. The mech. odometer still is acurate but the speed is usually 15 to 20 mph high and unsteady. Anyone have any tips or seen this before?
Thanks
Old Jan 23, 2003 | 10:22 PM
fastf150's Avatar
fastf150
If you are absolutely sure the odometer is accurate...then the problem is in your speedometer itself. As both the speed and the odo are driven off of the same input. Which is either a speedo cable or a DSS (driveshaft speed sensor).
Old Jan 24, 2003 | 07:16 AM
DoubleA's Avatar
DoubleA
if there is metal in the rear end it can throw off the speedo too
Old Jan 24, 2003 | 07:35 AM
steve83's Avatar
steve83
I'd agree that it's a fault inside the speedo head. There's no cable in new vehicles - they use an electronic sensor in the driveline.
Old Jan 24, 2003 | 10:22 AM
jim henderson's Avatar
jim henderson
Yeah, I have seen exactly this symptom in my 94 F250. The problem usually gets worse, and your cruise control will probably stop working if the needle jumps enough. Eventually it will also set the ABS light.
The speed sensor in the rear end was the problem in my case.
Good Luck,
Jim Henderson
Old Jan 25, 2003 | 08:54 PM
oldstylefseries's Avatar
oldstylefseries
Common problem on 96 Windstars. They didn't get enough lubricant at the factory. THe only fix is a new Speedo.
Good luck
Old Jan 28, 2003 | 08:23 AM
Wishbone's Avatar
Wishbone
Thanks oldstyle I was afraid of that.
2zwudz
Nov 30, 2013 06:43 PM
jayzeller79
Mar 2, 2008 09:01 AM
technomon
Nov 17, 2007 12:51 AM
whatzup
Jun 30, 2006 03:09 PM
thesprocket26
Jan 5, 2005 06:18 PM
