speedometer wont work
Old Feb 26, 2008 | 10:08 AM
jayzeller79's Avatar
jayzeller79
i have a 89 ford f250 4x4 7.3 with a 5 speed, and my speedometer
wont work. would it just be the cable or a speed contol ???
Old Feb 26, 2008 | 10:34 AM
dakotajeep's Avatar
dakotajeep
PLC7.3 has a good troubleshooting matrix. He will probably post here soon......
Old Feb 26, 2008 | 11:22 PM
PLC7.3's Avatar
PLC7.3
If you have the trans mounted speedo cable, over time the gears will get chewed up both inner and cable end...... You can get the parts at ford or trans shops. They go by color so take the parts.......or a photo. Is the cable attached to the cluster.....
Was it working before........
Old Feb 27, 2008 | 07:49 AM
jayzeller79
i got the truck three months ago and it didnt work. it was unhooked
from the cluster, I hooked it back up and it dont work, it dont
jump or anything...
Old Feb 28, 2008 | 12:23 AM
PLC7.3's Avatar
PLC7.3
Are you sure the cable is hooked up at the cluster, they are very finicky and must lock in correctly.
Check out this info...if yours is the same...
http://photos.ford-trucks.com/showphoto.php?photo=11823&papass=&sort=1&thecat=50 0
Old Feb 28, 2008 | 08:12 PM
speedrdr's Avatar
speedrdr
http://photos.ford-trucks.com/showph...t=1&thecat=500
PLC7.3, thanks much for posting that link. maybe that's why i couldn't get my cable to release 'cause i was squeezing BOTH sides of the do-hickey. not with pliars though, couldn't get anything but my hand in there... should be able to change out cable now with that help.
speedrdr
Old Mar 2, 2008 | 09:01 AM
jayzeller79
ya its in all the way.
dlsoc3
Sep 8, 2022 03:16 PM
Steve49841
Apr 1, 2015 06:25 AM
Stevenbowman23
Mar 23, 2015 12:12 AM
Turmand
1983 - 2012 Ranger & B-Series
Mar 15, 2015 10:54 AM
jim33067
Aerostar
Jan 29, 2014 09:01 PM
