Sponsored by: Real Truck
speedometer failure
Old Apr 5, 2006 | 07:52 PM
whatzup's Avatar
whatzup
speedometer failure
i have a 97 f250 heavy duty truck. the speedometer & oddometer will all of a sudden go out ,then the tranny will start miss shifting .sometimes the overdrive code light will start blinking. the code will be speed senser malfuntion,i allready replaced the speed senser a couple of times even solderd the connection .and had wiring checked. but when the speedometer goes out i can hit the dash and the speedometer will come back on then no more miss shifting till speedometer goes out again. can it be the instrument cluster or what ?????????????
Old Apr 5, 2006 | 07:58 PM
Beast12's Avatar
Beast12
Hi whatzup and Welcome to FTE! Someone should be along to answer your question soon but I am thinking possibly a defective VSS (vehicle speed sensor). It is located on the top of the differential I believe.
See ya in the forums!
-Matt
Old Apr 5, 2006 | 08:06 PM
whatzup's Avatar
whatzup
i have allready changed that a couple of times
Old Apr 5, 2006 | 08:22 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Hitting the dash - to me means a loose/corroded connector on the dash
Old Apr 5, 2006 | 08:26 PM
Beast12's Avatar
Beast12
DOH! Sorry, I read right over that! My bad.
-Matt
Old Apr 5, 2006 | 10:12 PM
99f350sd's Avatar
99f350sd
Sounds like you have a wiring connection issue. Wiggle wires and connectors etc. Tough to find.
Dick
Old Apr 6, 2006 | 09:25 AM
wiingnut's Avatar
wiingnut
I agree check for a loose or corroded connection
Old Apr 6, 2006 | 08:55 PM
whatzup's Avatar
whatzup
so you dont think its the cluster?
Old Jun 30, 2006 | 03:09 PM
bettendorf's Avatar
bettendorf
Is it fixed now and what did it end up being?
Baldy66
Aug 24, 2012 11:30 PM
jdcrew
Apr 29, 2011 11:57 AM
froddinjarebear
Sep 10, 2008 07:23 PM
paulcalif
Nov 7, 2005 10:27 AM
Cheapskateracing
Electrical Systems/Wiring
Oct 3, 2004 12:31 PM
