hole in #5 piston
Old Mar 20, 2010 | 11:03 PM
  #31
tntitan00's Avatar
tntitan00
look i have a towing company with a 95 psd and i had a pretty catastrophic problem the hpop went out and sent small metal particles through the ipr then to the injectors and hung one of my injectors wide open dumping raw fuel into the number 5 cylinder well i thought i had not torqued down an injector properly as it was fuel knocking and i tried to drive it another 15 miles to the shop as it was smoking to be damned well i didnt make it needless to say i bought a hpop an ipr valve an injector and a number 5 piston and rings. and this was at 202000 miles i now have 308000 on the same motor knock on wood but no problems since not even smoke at startup besides a tranny but this 450 gets worked hard everyday sometime pulling loads of 15 to 20k at times so i would say put a piston in and forget it but knowing what i know now ford did this work for me and all said and done parts and labor was $5000 and a reman engine from ford here in nashville is $7000 so unless your gonna do it yourself you might as well get a reman with the 100000 warranty.. but either way just wanted to assure you that if you want to replace just a piston you will be fine ford even warrantied all the work they did for me for 12000 miles if they didnt think the engine would hold up they wouldnt have done it hope this helps
Old Mar 21, 2010 | 04:24 PM
  #32
drivembig's Avatar
drivembig
Check this one out.
1997 7.3 TURBO DIESEL ENGINE 444E POWERSTROKE LOW MILES : eBay Motors (item 110507078149 end time Mar-24-10 13:51:15 PDT)
Old Mar 21, 2010 | 05:05 PM
  #33
DRRXR's Avatar
DRRXR
Just in case your thinking of another
This one does not look too bad. SCROLL after clicking
Ford : F-350 : eBay Motors (item 330408769355 end time Mar-07-10 21:15:29 PST)
Old Mar 24, 2010 | 12:47 AM
  #34
1950gmcelc's Avatar
1950gmcelc
Thanks for all the help I found a guy out here that buys and sells wrecked powerstrokes. He told me he probably get a used motor out of a wrecked truck with about 150000 miles on it and install it for $3100. I then figured $500 for stage 1s and couple hundred for a exhaust system. So now I have to wait for my tax return to hurry up and get here so I can send my injectors off and send my truck in.
Old Apr 12, 2010 | 11:39 PM
  #35
packarman2000's Avatar
packarman2000
question?
were are you getting stage one injectors for $500. can you provide a link and are they good injectors? thanks
Old Apr 13, 2010 | 06:29 AM
  #36
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Rosewood Diesel Shop
To anyone out there with a burned Piston.
You can NOT just simply drop the pan, pull a head, hone the cylinder and install a new Piston. Little bits of aluminum Piston get mixed in with the oil, which means ALL of the bearings are shot, ALL of the injectors need to be overhauled, the turbo bearings are damaged, HPOP needs cleaned/replaced, etc.
The motor needs a COMPLETE tear down and overhaul when this happens.
I know first hand of this (and any reputable engine builder will tell you the same thing) from working with a customer suffering from rectal cranium inversion, and if you don't do anything about it you'll regret it later!
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
big-ugly
22
Jan 8, 2018 07:49 PM
Rusty96
Aug 4, 2017 05:32 PM
Ugly-duck
Jul 19, 2017 10:04 PM
MattMac
Feb 13, 2017 10:05 AM
1966F100FE352
Oct 2, 2008 08:03 PM
