Push rod orientation
Old Mar 9, 2010 | 08:58 PM
Damonkr's Avatar
Damonkr
I was pulling the injector cups in a friends truck today and noticed that one bank had the pushrods installed with the shiny brass colored end up and the other had the silvery end up. Which way is right? I compared the holes in the ends of the pushrods and I see that one is smaller than the other so i need to set this thing back up correctly.
Old Mar 9, 2010 | 09:06 PM
Damonkr's Avatar
Damonkr
side note
Also I had one cup obviously cracked and i suspect at least one more was leaking around the tip.
What should I do with this injector?? I think it should be replaced but don't want to do that if that is not necessary. The one on the left is the one in question.
Old Mar 9, 2010 | 11:34 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
The copper end goes up on the push rods. The injector tip is black from not being properly torqued and/ or from the copper washer burning away. Should be fine just clean it and make sure to put all new o-rings and copper washer on.
Old Mar 10, 2010 | 09:07 AM
Damonkr's Avatar
Damonkr
Thanks Clay. I thought that the push rod felt like it fit the rocker better with the copper end up. Can't figure out why the one side is upside down. I hope it didn't ruin one side of rods since its been that way for at least 50000mi or so.(guess since thats when gary bought it) They seeme fine and the rockers look fine.
I E-Mailed you pics of that tool in use.
chiefsfootball
Jun 29, 2016 04:21 PM
Montync
Apr 7, 2016 01:22 PM
SwOkcOffRoader
Apr 2, 2016 10:07 AM
ford truck oldboy460
Jan 28, 2009 09:28 AM
gtex
Nov 15, 2003 10:55 AM
