Weird pushrod
Old Apr 7, 2016 | 02:40 AM
Montync's Avatar
Montync
Weird pushrod
Got a 86 302 mustang motor to swap int my truck. When I went to check to make sure it had a roller cam I noticed the pushrods didnt look normal. All of them have this what I guess you would call a sleeve at the same spots on all of them. If you were to lay it flat on a table one end would remain in the air. Is this normal. What is its purpose? Sould it be towards the pushrod end or the lifter end?
Old Apr 7, 2016 | 08:26 AM
Montync's Avatar
Montync
I pulled them again this morning upon inspection it says UP. I guess its only purpose is to show what direction to put it.
Old Apr 7, 2016 | 08:39 AM
baddad457's Avatar
baddad457
Never seen a factory pushrod like that. The 86's heads (E6SE) have shorter valve stems because the valve pockets are deeper into the head than all other SBF heads, but the pushrods were the same length. Someone may have been into that motor since it was new and replaced the pushrods with an aftermarket set.
Old Apr 7, 2016 | 08:43 AM
Montync's Avatar
Montync
They measure 6.25..
Old Apr 7, 2016 | 08:45 AM
baddad457's Avatar
baddad457
That's the std length roller cam 302 pushrod.
Old Apr 7, 2016 | 01:22 PM
xlt4wd90's Avatar
xlt4wd90
My 87 5.0 HO has the same sleeve on the pushrods. My guess is it's to help dampen certain vibrations.
spikinfool05
Feb 17, 2014 08:22 AM
Customcab
Nov 16, 2007 03:33 PM
robertbourque
May 14, 2007 03:46 PM
Mid_Mo_F100
Oct 2, 2005 11:54 AM
bronco840
Dec 14, 2004 11:13 PM
