this may sound dumb
Old Mar 9, 2010 | 05:43 AM
hotter69's Avatar
hotter69
this may sound dumb
i have a 352 in my 66 f100 4x4. so heres my question. the 352 is in the same family with the 428 so does that mean that i can bore it out to 428 and put all 428 insides? so it would be the same as a 428 from the factory.
Old Mar 9, 2010 | 10:49 AM
oldbrokecowboy's Avatar
oldbrokecowboy
No such thing
No such thing as a dumb question, unless you already know the answer. Yours has been covered many times here, if you make use of the search feature I'm sure you will get all the information you need. Good luck and keep us up to date on your build. OBCB
Old Mar 9, 2010 | 11:34 AM
bertha66's Avatar
bertha66
Same type of block, but the cylinders most likely will not take that most boring. You would need to have the block sonic tested to know. I have a 66 F100 4x4 with a 390 HiPro Fairlane engine, great combo, lots of power and good gas milage.
Old Mar 9, 2010 | 01:50 PM
Bear 45/70's Avatar
Bear 45/70
The short answer is not likely. As mentioned the cylinder walls differ in thickness even though externally the blocks are the same. I actually took a 390 (same bore as a 360 which is your block 0.050" oversized) out to the 406/428 bore of 4.13". But that was an early 60s 390HP block which I turned into a 406. I've never seen another one that would go there though.
Old Mar 11, 2010 | 10:51 AM
hotter69's Avatar
hotter69
what do u mean "go there". do u mean a block that is in good enough shape, nobody else has done what u have?
Old Mar 11, 2010 | 10:56 AM
bertha66's Avatar
bertha66
Not a block that is in good shape, but one that has cylinder wall thick enough to bore out that much and still have anything left. When the walls get to thin, engine will over heat, or the boring bar will cut though the walls.
Old Mar 11, 2010 | 12:02 PM
Bear 45/70's Avatar
Bear 45/70
Many have tried to go out to the 4.13" bore of the 406/428 but most blocks end up like bertha66 said either with overheat problems or a hole in a cylinder wall. They weren't cast to be bored that much.
OrangeJuice
Jul 28, 2010 08:55 PM
hotter69
Mar 10, 2010 08:27 AM
FordTrucksKickGM
15
Oct 31, 2008 04:03 PM
my79f
15
Sep 13, 2005 01:15 AM
hjm3inpa
Aug 2, 2003 08:35 AM
