sheared stud blues
Old Mar 8, 2010 | 03:56 PM
paul f machak's Avatar
paul f machak
sheared stud blues
Sheared off 4 exhaust mani studs. Nearly impossible to drill out in truck. Am in process of removing intake and heads. Have all bolts out but intake won't budge. Suggestions?
Old Mar 8, 2010 | 03:59 PM
paul f machak
Suggestions for seperating intake from heads w/o damaging anything on '70 F-150 360 cid? All bolts removed, intake won't budge.
Old Mar 8, 2010 | 07:17 PM
Ford_Six's Avatar
Ford_Six
Standard procedure is drain coolant, pull valve covers, rocker rails, pushrods (keep in order), pull carb and install engine lift plate, remove distributor, unbolt intake and then use crane to separate. There are five bolts per side, and the thing weighs about 80lbs plus being stuck to the engine by 35-45 years of habit.
Old Mar 8, 2010 | 08:42 PM
marks69's Avatar
marks69
i slid a thin flat bar in between mine when i had to take the heads off. it's red and used for pulling trim off. just wiggled it through the gasket then lightly pried.
gl
mark
cabloom300
Nov 11, 2012 12:00 PM
ktm747
Nov 16, 2009 02:39 PM
Recycleking
Aerostar
15
Oct 11, 2007 10:28 PM
Steve Shaw
Sep 20, 2006 06:39 PM
Zigracer
Jan 5, 2003 08:45 PM
