Brakes still pulsating
When you bought the Powerslots, are you sure you got the cryo treated rotors? I'm not being a smart azz. I almost ordered the wrong ones once, that's why I ask. Plus, you're sure the supplier gave you cryo treated rotors, right? Were they ordered online?
Also, was it pulling to the left before? And did it stop each time you did the brakes, but then come back?
Stewart
Of course, depending on the mileage, both the number of miles and the type of miles, you may have a combination of issues.
For the pulsating......
I had the OEM rotors resurfaced a few times in an attempt to solve the issue. And it was bad enough to concern me. Not just an annoyance. The machining worked for, perhaps, 200 miles. But then the usage removed enough soft rotor material and left sufficient hard rotor material to cause the pulsating to return.
Finally I installed new chamfer drilled and slotted rotors with the pads that the rotor manufacturer provided. I believe that if a manufacturer sells an accompanying product that they may have tested them together and that would be the reason they are recommending them. I happen to buy Royalty Rotors (http://www.royaltyrotors.com/) from a company that is now out of business. Royalty is still in business. Just the company I bought them from is gone.
I did have an issue when driving through Montana when it was 23 degrees, I was doing 70 on interstate 15, and I had to apply them suddenly. I suspect that the cold weather and the heat generated by the sudden deexcelleration played a part in the pulsating. Not nearly as bad as it was prior to the rotor/pad installation. However, now that I have put a few more miles on them, the pulsating, which is really only a hint of doing so, is gone about 99% of the time.
So, I would recommend that you consider drilled rotors (Completely drilled through, not the ones that are only partially drilled through. You want the cooling fins to pull the air/heat/gases through the holes and exhaust it for complete efficiency. Now, some guys will tell you that the holes reduce braking efficiency because of the loss of surface. However, the reason that the fully drilled holes work is because the gases that build up between the pads and the rotors during use are evacuated through the holes and the pads actually contact the metal and no longer hydroplane over the rotor on the gases.)for the pulsating and the other ideas for the pulling.
I know my writing style could use improvement. But, as convoluted as it is, I hope you get the meaning from what I have said.
What I am seeing on mine points to the ABS. If I change all four I get 30k-60k miles out of them without pulsation. It depends on how much I tow and how much mountain driving I do.
I have almost 200,000 miles on my EX.
The last time I did my brakes - about 15,000 miles ago - I just did the fronts.
I did this as an experiment. At about 10,000 they started pulsating.
What I have noticed though, is if I let off the brake and then reapply there is less or no pulsating.
I think it is the ABS reacting to not having good brakes on all four corners.
When I do brakes, normally I replace all four rotors, pads and slider pin sets.
I will be going through mine soon and am planning to replace all four and inspect the wheel speed sensors and run any ABS test with Autoenginuity.
I'll post results and milage after the fact.
I'm using Motorcraft parts as always.
From the Hawk web site: The only thing I would add is try to park it overnight if possible vs. just the 15 mins. to allow the system to fully cool down.
Burnishing Instructions
1. After installing new brake pads, make 6 to 10 stops from approximately 30-35 mph applying moderate pressure.
2. Make an additional 2 to 3 hard stops from approximately 40 to 45 mph.
3. DO NOT DRAG BRAKES!
4. Allow 15 minutes for brake system to cool down.
5. After step 4 your new pads are ready for use
. I'm beginning to think maybe I got a defective set of cryo rotors and am thinking of trying another set, but I'm a little hesitant to throw more $$ at this than I already have!
When you ordered the cryo treated rotors, how long did they take to have them treated then sent out to you? How long did you have to wait?
Stewart
