Sponsored by: Auxito
Running Rough & Braking Problems
Old Sep 24, 2008 | 01:40 PM
shucky's Avatar
shucky
Ok guys I have a 1999 F-150 5.4, auto, 4x4 and I have 2 problems I need help with PLEASE !!!!!
1st Problem If you hold the accelerator pedal to 1500 rpms it drops to 1200 then rises back to 1500 then drops again, and countinues. If you are under acceleration and reach 1500 rpm the truck shutters and bucks then smoothes out after 1500........... What is going on....?
NOTE : It also smells rich in the exhaust. I had a EGR code, so I replaced it but it must have been a seperate issue.
2nd Problem is my ABS light is on, we have replaced the speed sensor, with no luck. The brakes pulsate while applying them. Wore out a pair of rotors and pads in about 6k miles. Replaced the pads and rotors again and now 2k miles later the brakes are already so nasty they give you a headache while stopping.
Here is the kicker, when the brakes are wet, the ABS light DOES NOT come on & the ABS works properly, as soon as it dries out, bing - the light comes on and the brake pedal start pulsating again and no ABS working.
Thanks in advance-
Old Sep 24, 2008 | 02:26 PM
KingRanchMan02's Avatar
KingRanchMan02
Welcome to FTE shucky! How many miles are on the truck and do you have a history with it?
Your first problem sounds like a possible TPS problem. Could also be a misfire in the engine.
Does your truck have 2WABS or 4WABS? If it is 4WABS, then check the senors and sensor rings at the front wheels. Good luck!
Old Sep 24, 2008 | 03:01 PM
shucky's Avatar
shucky
Sorry about that... The truck has 145k miles. The plugs were changed about 7k miles ago. How do I check the TPS, would that cause it to run rich?
How do I tell if it is 4W or 2W ABS? Another thing that got me thinking, there is a high pitched squel coming from the drivers front brake, could a caliper be sticking, how do I check that?
Old Sep 24, 2008 | 03:29 PM
KingRanchMan02
I case you don't know what the TPS is, it is the throttle position sensor. It will be a rheostat that changes resistance when the throttle is operated. if the signal is erratic, the engine RPM will fluctuate.
If you have 4WABS, then there will be ABS sensors at the front wheels. You may have a caliper sticking due to collapsed rubber brake hoses between the caliper and the frame. A collapsed hose will allow fluid to flow out into the caliper but won't let it flow back to the master cylinder when the brakes are not being applied. Replace the hoses. Good luck!
Paul Larsen
2004 - 2008 F150
Sep 8, 2013 10:18 PM
mikulskn
Jun 26, 2013 11:23 PM
KYMEDIC
2004 - 2008 F150
Oct 9, 2011 11:36 AM
hood
Aug 7, 2007 01:44 AM
Orlie
Jun 7, 2005 11:11 PM
