Down Pipe Issues
Old Mar 9, 2010 | 04:19 PM
  #31
Krisx125's Avatar
Krisx125
my dp is rubbing my tranny lines and everything else...So im going to get a band clamp and put it on if all else fails...heat tape to pad it where its rubbing.
Old Mar 9, 2010 | 08:52 PM
  #32
fmco_muddin's Avatar
fmco_muddin
So I was looking at those pictures and trying to figure out where to cut my new dp at to make it into a two piece. can you measure from bottom of bell to where the split is please? I am just going to cut it and use a flat band to put it together once I get it in.
Old Mar 10, 2010 | 03:30 PM
  #33
Brown Falcon's Avatar
Brown Falcon
just cut the "cobra head" off at the top by the turbo and it should pull out from the bottom in one piece
Old Mar 10, 2010 | 07:52 PM
  #34
fmco_muddin
Sorry I should have specified. My new DP is a one piece and I am going to cut it to make it a two piece to get it in.
Old Mar 10, 2010 | 10:05 PM
  #35
wheelie31's Avatar
wheelie31
you planning to use a pipe expander and then clamp it back together after you cut it, You can cut it anywhere you like as long as u can fit the clamp in there to secure the 2 pieces back together.
Old Mar 11, 2010 | 06:34 PM
  #36
Duradan's Avatar
Duradan
Originally Posted by 427 fordman
I agree the porta power would be best. The only reason I didn't use one is I remembered when I went to get it that someone borrowed it and never gave it back. Made due with a sawzall, block of wood, and a 4 foot pry bar.
X2 exactly
Old Mar 11, 2010 | 08:25 PM
  #37
FARM69's Avatar
FARM69
When I had to fab up my downpipe for the new turbo I created one like the "downpipe" that I previously had. My system is pretty tight since my charger sets lower in the valley than the stock or H2E. I have a vibration sometimes, usually when I'm going through pot holes or twisting the frame. Nothing that is not unbearable.
In your case you need to cut the DP when it's at the 45 degree angle. I would say in the middle, but a little closer to the top so it clears the transmission bolts. I'm not sure if the automatic transmission is different.
In any 3" 2 piece DP install your gonna need to "snake" aka spin it around until you can get it to fit in between the firewall and head.
I thought it might be appropiate to add some pictures of the downpipe on a one inch grid. Hopefully they will make things easier for you.
Credit Neal for the pics... This is what I went off on mine...
Hope that helps.
Old Mar 11, 2010 | 09:26 PM
  #38
fmco_muddin
Ok cut the factory one out oh did it feel good to cut that POS out and then cut my new one and it is NOT the right one!!!!! The one I have does not bend around right away like the one in the first picture above does. So I am just going to buy one that I know is right for my truck. My question is where does everyone buy theirs from or recomend buying it? I simply do not have the time to modify one up. Reps sent to farm69 and Neil for the pics
Old Mar 11, 2010 | 09:42 PM
  #39
JamesHajek's Avatar
JamesHajek
I believe riffraff diesel has MBRP downpipes for like 85 bucks or something. or Tymar performance has downpipes too.
Old Mar 11, 2010 | 09:45 PM
  #40
FARM69's Avatar
FARM69
I should have specified that the one in the picture is slightly different at the neck... aka the top where it connects to the turbo. The rest of it is still the same.
The bottom of the pipe should still be the same. The pipe in the picture is for a H2E turbo so it's going to be a tad different. Your still going to make your cut on the 45 degree piece. If it helps, hold your pipe up like its installed and visualize the area where it starts to pull away from the heads just enough to get a clamp in there and clear the firewall/transmission.
Why is your downpipe only in one piece?
Old Mar 11, 2010 | 09:54 PM
  #41
fmco_muddin
I got it from a buddy as a bonus gift when I bought my tuner from him.
Old Mar 11, 2010 | 09:56 PM
  #42
FARM69's Avatar
FARM69
Ic ic. I'm sure you have the right pipe, although I've never heard of any single piece ones. Doesn't mean that they don't exist.
How did the cutting go? Is it going to work?
Old Mar 11, 2010 | 10:16 PM
  #43
fmco_muddin
Its not going to work. Im just going to order a two piece from some where.
Old Mar 12, 2010 | 09:02 AM
  #44
nateairman's Avatar
nateairman
Sounds like you got a 3" dp off of a 7.3 out of a E-series vehicle. I have one of those laying around thinking it would work but there is no way even if I mod the heck out of it.
Old Mar 12, 2010 | 02:19 PM
  #45
Brown Falcon
I got mine from Bean's Diesel Performance for $85, on the site it said "MBRP" but the box I got said "Diamond Eye", but either way it fits good and was easy to install...
if you want one the expands at the bottom like 3" at top and 3.5" or 4" at bottom go with Tymar, call Dale and he can help you. THey cost more but are good pipes. You can also have him ceramic coat it for you.
