hello
Old Mar 6, 2010 | 05:33 PM
slamin79's Avatar
slamin79
hello
i just perchest a 1979 ford f150 shortbed 4x4, few minor issues, hoping you all could point me in the right direction, the guy i bought the truck from used to start it with the key, well he told me it had set for about 9 months with the windows down not started, so when he goes to start it nothing, keyswitch is not working at all no interior lights or dash lights, nothing, its like the battery is out of it. so this is what he does,, runs a wire from the coil to the battery and jumps the truck from the silinoid and she starts every time and runs great. here is my Q'S(sorry for the long story)what can i do to correct the problem is it in the keyswitch, or maybe a mouse has gotten into something. also i cant get the headlights or brake light to work. could this all be 1 issue... thanks alots guys.any and all help is greatly appreciated
UPDATE::: guys i got out this morning trying to figure out the wiring, well im not getting any power to the fuse box any place i can look for the problem
Old Mar 6, 2010 | 05:52 PM
ford1977owner's Avatar
ford1977owner
hello welcome to FTE greatest ford forum on the web! alot of great guys on here to help with your questions...although im not really much into the wiring part i try to stay away from that but i just wanted to welcome you...also would be nice to see pics my friend!!
Old Mar 6, 2010 | 05:57 PM
slamin79's Avatar
slamin79
thanks i just got the truck today i get some pics up asap.. thanks again
Old Mar 6, 2010 | 06:15 PM
fmtowman's Avatar
fmtowman
Check the wiring on the hot side of the solenoid. That is the side that is connected to the positive terminal of the battery. The cold side of the solenoid is connected to the starter and is only energized when the key is turned to the start position. There are one or more fusible links built into the smaller wires connected to the hot terminal which feed everything else but the starter. Sounds like you have a blown fusible link or a broken wire. Maybe not but this is where I would start looking. Hope this helps...
Old Mar 6, 2010 | 06:20 PM
460/5's Avatar
460/5
Zombie Survivalist
i would start with cleanin the battery terminals and checkin for wires that might be worn/chewed through and shortin.
welcome to !!!
Old Mar 8, 2010 | 09:06 AM
slamin79's Avatar
slamin79
update on top
Old Mar 8, 2010 | 10:42 AM
460/5's Avatar
460/5
Zombie Survivalist
check the power wires from the battery.
Old Mar 8, 2010 | 10:49 AM
starmilt's Avatar
starmilt
The lights work seperately from the ignition switch so your problem is going to be no power to the cab. Have you checked to see if you have any voltage to the fuse box at all. I suggest like towman said start at the hot side of the selonoid anw work from there. Also check all wiret at the alternator and to the voltage regulator, I'm betting you have a bad fusible link.
Old Mar 8, 2010 | 10:51 AM
460/5's Avatar
460/5
Zombie Survivalist
read the update in his original post.
Old Mar 8, 2010 | 11:03 AM
starmilt's Avatar
starmilt
I see it now. but he still needs to start at the selonoid and trace the power loss.
Old Mar 8, 2010 | 07:31 PM
slamin79's Avatar
slamin79
guys thank alot for the help and advice i'll start from the battery tomarrow to the silinoid and go from theirhopfully
IsaLandr
Dec 17, 2014 12:57 AM
dieselaholic
Dec 22, 2011 08:42 PM
redthhies
Apr 9, 2010 09:25 AM
grady w
Electrical Systems/Wiring
Aug 26, 2003 01:46 PM
