A/C compressor cycles on/off
With the heat/AC controls in any position other than "off" the electric clutch on the compressor cycles on and off with an audible click. Sounds like the semi-fast click of a time bomb in a cartoon. You know, tick, tick, tick at rate that increases to about 1 per second. Actually, it starts slower than that then as a few seconds go by, the rate of engagement/disengagement increases.
If I turn the heat selector to "off" it stops completely. If I turn it to A/C it engages fully for about 18-20 seconds, then starts cycling on and off.
I have no idea if this is normal or not, but I am suspecting not because I think I would have heard it before in all the years I've had the truck.
With the engine off, I can spin the compressor by hand. There is some resistance, about what I guess I'd expect from a compressor. But it certainly doesn't feel bound up or abnormally tight in any way.
I have video of it, I just have to figure out how to attach it or otherwise make it available for you guys to see.
It'd be cool to be able to do whatever I have to do in a leisurely manner instead of having to fix it overnight before a scheduled long trip in the middle of a hot summer.
Any ideas/suggestions?
Thanks!
******** width="425" height="344"><param name="movie" value="http://www.youtube.com/v/jU_EKSQ-M74&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jU_EKSQ-M74&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed>*********>
It should never cycle on in vent or floor.
I'll get it recharged and see if that does the trick.
I may have been mistaken about it engaging on vent or floor. I was flipping the selector back and forth trying to find which ones made it stop, not necessarily which ones made it cycle. I just know it was doing it on mix because that is where I usually keep it in the winter time.
Air Conditioning Troubleshooting and Repair
I am leaning towards the low refrigerant angle because when I turn it off entirely for a few minutes, then re-engage it, the clutch stays engaged for about 15-20 seconds, than starts to cycle.
To me, that kind of rules out the electrical connection on top. I had wriggled that around, too, with no change in performance.
So I'll make a stop at the garage and get it recharged with refrigerant and see how that goes.
