Sponsored by: Real Truck
Door lock help
Old Mar 5, 2010 | 06:48 PM
maxont's Avatar
maxont
Door lock help
Okay so i have done the "ford door locks fixed" with the foil around the metal thing, but i have a problem!! 6 months after doing this for some reason a 10 amp fuse blows when i use my power seats, when the fuse blows my door locks go erratic and lock/unlock constantly until i replace the fuse. Well i took my truck to a shop to get something else fixed and the fuse blew while at the shop. So the locks went off and the shop had no idea what to do and did nothing to try and stop them... they went untill they stopped working all together. My guess is that the motors have been burnt up now? When i hit the lock button i can hear the relay switch but no lock movement? Thoughts anyone? is there any other fuse or anything that could have blown and stopped the motors from burning up? or a relay?
Thanks
Old Mar 5, 2010 | 09:03 PM
cworley250sd's Avatar
cworley250sd
I fixed my locks on my old truck with the foil trick, worked great, had it two years after the fix and no problems, I hope that the fix is not related to your new problem.
rhino991
6.7L Power Stroke Diesel
30
Oct 25, 2016 04:22 AM
mrjimbov
Electrical Systems/Wiring
Nov 23, 2014 07:20 AM
ryankerr
Mar 5, 2014 10:06 AM
cc_rider
May 23, 2013 08:32 PM
sdswan
May 1, 2006 09:01 PM
