00 Ford F150 power door lock problems. Please help
Hello,
Im trying to hook up my power door locks to my command start. Im having trouble getting it to work. Ive tried a number of relay diagramns from the12volt.com. Ive tried actuators/reverse polarity and it blows both my factory door lock fuse and the fuse I have supplied to the relays. Ive also tried 5 wire alternating 12 volt positive door locks, and 3 wire positive door lock combinations. Both of these combinations the relays click back and forth fine with the actuators unhooked, when I connect the actuators the doors unlock with the factory switch but when I unlock with my remote it blows the fuse. Any suggestions on how to properly connect the actuators?
Thank you,
Thank you,
Yes I added a remote start. Everything works fine with my remote start and the two relays I have added. But when I try and hook it up too the two actuator wires under the dash it always blows the fuse. I have checked at the door lock switch at the drivers door and I am tied into the correct wires under the dash. One gets power in unlock and the other gets power in lock. Even if I just try jumping fused power to either of those wires at the switch itself it just blows the fuse. Any suggestions?
torque head
05-13-2016 09:20 AM
