4x4 engaging while driving
Old Mar 3, 2010 | 11:37 PM
jdanroth's Avatar
jdanroth
My 2007 Ford 150 makes a horrible blender sound sometimes when i drive it. It almost sounds like the 4x4 is trying to kick in. The sound goes on for 20 seconds or so and stops.
Anyone else with this problem?
Old Mar 7, 2010 | 04:35 PM
LxMan1's Avatar
LxMan1
Welcome to the forum. Can you tell where the noise is actually coming from?
Old Mar 8, 2010 | 05:45 PM
96f150's Avatar
96f150
More than likely your shift solenoid thats on the pass side firewall has ingested water and is shorting out and putting it in and out of 4x4. Next time you here the noise, pop it in 4x4 and see if it goes away.
Rich
Old Jun 11, 2010 | 03:18 PM
Uberbob102000's Avatar
Uberbob102000
It sounds kinda like ice in a blender and is coming from the front of the truck?
If so, I believe your front needle bearing is going bad, and if you have the ESOF system you may have to replace the solenoid because of a rotted or broken vacuum line.
http://www.frontiernet.net/~jmray/F250NeedleBearings.htm
Welcome to guzzle's 4x4 Needle Bearing Maintenance Web Page
Those should help you if that is your problem. I had the same issue with my truck after I snapped off the vacuum line while being adventurous. It's not really that hard to do, I did both sides in about 2 or 3 hours.
PatchMcGav
2004 - 2008 F150
Nov 7, 2014 08:46 PM
ptree114
Sep 16, 2011 08:27 PM
65eglide
2004 - 2008 F150
Mar 6, 2011 08:09 PM
MartinF150
1997 - 2003 F150
Sep 12, 2010 02:03 PM
rogeroz
2004 - 2008 F150
Oct 1, 2007 06:17 PM
