Fx4 Problems
Old Sep 24, 2007 | 03:10 PM
rogeroz's Avatar
rogeroz
Fx4 Problems
I have a 2004 ford f150 fx4 4x4 with 97,000.00 miles some times while im driving it it sounds as if their is a leaf rake being dragged behind the truck.
while under a load or pulling my lawn trailer its moore noticeable. it almost sounds like the 4x4 drive shafts have not fully disengaged on the front left side.
can any one help? the truck is a automatic with overdrive as well. but when you put it in 4 wheel high the sound goes away.
Old Sep 24, 2007 | 03:48 PM
Fishin76's Avatar
Fishin76
I would say that your t-case or auto locking hub is not fully dis-engaging. unfortunately, sounds like a visit to your dealer.
Old Sep 24, 2007 | 04:11 PM
NASSTY's Avatar
NASSTY
It may be a bad IWE solenoid or a vacuum leak to the IWE.This will make your hubs try to engage when in 2wd.
Old Sep 24, 2007 | 04:31 PM
4DOORSR's Avatar
4DOORSR
Yup, I have the same problem, and have had it 3 times now. I'm so sick of it I'll just drive it until the snow comes and then I'll get it fixed. The solenoid is only 50$. Make sure your vaacume lines are routed the right way and aren't rubbing on anything.
Old Sep 25, 2007 | 06:45 AM
generalee31184's Avatar
generalee31184
IWE Solenoid again!!
Old Sep 25, 2007 | 07:36 AM
TRITON-ic's Avatar
TRITON-ic
Not contesting the solonoid answer, but I had a explorer that did the exact thing. It was a bad hub.
Old Sep 25, 2007 | 05:06 PM
rogeroz's Avatar
rogeroz
up date unpluged
ok guys, I traced the vacume lines back to the firewall and found a little round
electronic piece with one wire conector going into the top of it. I unpluged the thing and the noise went away.Is this the selonoid that needs replaced? it is located on the passenger side firewall near the top right hand corner. your help is greatly appreciated.can this item be purchased at a parts store or is it a dealer only item?.
Old Oct 1, 2007 | 06:17 PM
78broncoman's Avatar
78broncoman
Ive had the same problem with my 07 screw anyone talked with ford about it yet??
Jay David
Vehicles for Sale
Dec 30, 2016 02:39 PM
07F150Lariat5.4
2004 - 2008 F150
Apr 8, 2016 09:33 PM
Dorito
2009 - 2014 F150
Jul 11, 2014 09:06 PM
geostone
1983 - 2012 Ranger & B-Series
17
Nov 26, 2013 09:00 PM
TMayberry
6.4L Power Stroke Diesel
Sep 15, 2010 10:35 PM
